Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Catalytic converter delete on CRD
    Hey guys,
    I have a mate with a 2008 CRD30 and has a hole in the Cat. I assume it's illegal to remove or delete it but what's the go? Given the cost to replace the Cat are most just deleting it? Any recommendations on exhaust replacements? Size and suppliers.
    He doesn't want it to drone so was concerned about going to a 3". Who has done what?
    I know nothing of 3.0s. What's the go.
    Cheers MR
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Hey guys,
    Cheers MR
    Beaudesert 2.75" for the win. Good sound, better tourqe down low and no overboost issue. Comes with a sports cat and egt bung
    ................on the road
    ________________________
    ______ 2017 D-Max _______
  4. The Following 2 Users Say Thank You to Maxhead For This Useful Post:
    Hodge (1st May 2017), MudRunnerTD (1st May 2017)
    So you refitted the cat. Have you got a link to the system mate
    175 Post(s)
    +1 to this.
    Had it on both my Patrols and my Navara. Perfect fit everytime everything included, straight bolt on.
    http://beauexhausts.com.au/
  7. The Following User Says Thank You to Hodge For This Useful Post:
  8. #5
    43 Post(s)
    Playtime 3" with cat and muffler.
    No loss of performance.
    No drone..
    A good note but not loud.
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
  10. #6
    462 Post(s)
    Which ever way Darren do not remove the CAT. With my old 3ltr I was pulled up twice, in the same place too, from an RTA check and both times the first thing they did was climb under with a heat gun and check for the cat. As far as I'm aware the fine is a few k if caught without. There is plenty of options available with performance cats to stick with a cat.
  11. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (1st May 2017), MudRunnerTD (1st May 2017)
  12. #7
    .......... TPC's Avatar
    63 Post(s)
    I got a Genie Legendex 3" and am happy with it, doesn't overboost and sounds good.
    http://legendex.com.au/site/index.ph...s/set-gu-2-lex
  13. The Following User Says Thank You to TPC For This Useful Post:
  14. #8
    43 Post(s)
    Maximum $10g fine for stuffing with emissions controls..
  15. The Following User Says Thank You to BigRAWesty For This Useful Post:
  16. #9
    Great feedback thanks Mark.
    Appreciate all the replies gents. I have sent a link for this thread to my mate who is not a member.
  17. #10
    462 Post(s)
    I'll just add to my comment about being pulled over by the RTA and the use of their heat gun. They use the gun to detect if the cat has been gutted or not. A gutted cat will show less difference in surface heat compared to a, not gutted, cat. So its easier for them to spot.
  18. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (2nd May 2017), MudRunnerTD (2nd May 2017)
