Page 835 of 1049 FirstFirst ... 335735785825833834835836837845885935 ... LastLast
Results 8,341 to 8,350 of 10488
  1. #8341
    109 Post(s)
    geez and here iu was thinking you were going to tell us about the huge hole in the arse you gave it.
    Pretty good approach and departure angles that one. Thats about it tho.
  2. The Following User Says Thank You to Plasnart For This Useful Post:
    MB (17th April 2018)
    472 Post(s)
    Yep, smartypants :-) Been thinking about starting a Blog on the subject although stuffed if I know how, please teach mate?
  5. #8343
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Ps... I paid $100 if Leah's nearby.
    I can feel a blackmail comin' on! Thirteen chickens and I won't mention it to a soul.
  6. The Following User Says Thank You to Touses For This Useful Post:
    MB (22nd April 2018)
  7. #8344
    175 Post(s)
    Just finished a quick oil change. 10 out, 10 in, 2 filters. Done. Now for a beer or 4.....
  8. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    GQtdauto (19th April 2018), MB (19th April 2018), mudski (19th April 2018)
  9. #8345
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Just finish install of Fabwitz 3" induction sys (complete works) to my 08 Patrol CRD.
    Airbox thru to throttle body (inlet manifold). To compliment current ECU remap (max boost 22psi) and scheduled install of stage 3 turbo (early May).
  10. The Following 4 Users Say Thank You to Bidja For This Useful Post:
    Hodge (24th April 2018), MB (24th April 2018), MB TD42 (6th May 2018), Yeti's Beast (24th April 2018)
  11. #8346
    Jul 2017
    37 Post(s)
    Made a bracket to secure my VNT solenoid off the Aux battery tray adjacent to the new air box.
    Run manual boost control (dawes/needle). So when I installed new air box and pipework I removed VNT solenoind and the fault code P0045 (solenoid open curcuit) came up and got limp mode. After re-connecting the solenoid this removed P0045 fault and now no limp.
  12. The Following User Says Thank You to Bidja For This Useful Post:
    MB (25th April 2018)
  13. #8347
    194 Post(s)
    Installed the Icom UHF today, into the existing dash Pod - waiting for a DIN facia plate to arrive to finish it off, all hooked up. Also found the source of my RS radio transmissions - soldered joint on antenna coupling had come adrift - so sorted that out. Then tested out the radio using the other uhf in the truck, raised the roofrack antenna - all good, packed up, drove the truck into the garage and wiped out the brand new RFI 3dbi antenna - faaaark. There goes another $150 down the toilet for lack of attention.
  14. The Following User Says Thank You to PeeBee For This Useful Post:
  15. #8348
    Nov 2010
    Getting a life...
    38 Post(s)
    Booked it in for new bearings and hubs so we can get to SA next week.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  16. The Following User Says Thank You to katwoman For This Useful Post:
    MB (27th April 2018)
  17. #8349
    194 Post(s)
    Both new pusher fans arrived this week, so spent the afternoon mounting them in front of the radiator. Bit of a mission, but the two fan now can push up to 3000CFM thru the radiator on demand, which i hope is enough to keep the temps down when doing 2000rpm at 1klm/hr up monster gnarly tracks in the heat. Now just have to set up the electrics and reinstall the grill and antennas etc. Thermos are additional to the mechanical fan that does a reasonable job up to rad temps of say 95 deg C , then its all over and temp just keeps rising. Topped out at 130 Deg c on the last trip simply because there was nowhere to stop on one track in particular - @MudRunnerTD's pinstripe applicator track I think its called!
    Fitted the replacement RFI UHF antenna that I stupidly left up before driving into the garage, BUT, when changing over the antenna cable found the FME-UHF fitting broken, so unable to connect then test. Expensive little fitting by the looks of it compared to the straight out PL259 or equivalent.
  18. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    Bidja (7th May 2018), GQtdauto (6th May 2018), MB (6th May 2018), MudRunnerTD (5th May 2018)
  19. #8350
    WA Wheatbelt
    23 Post(s)
    Topped up both diesel tanks today....$199.40.
    Can't complain. First time in 2 months.
    Been testing out the missus' new car lately. lol.
  20. The Following User Says Thank You to DX grunt For This Useful Post:
    MB (6th May 2018)
