Page 37 of 105 FirstFirst ... 2735363738394787 ... LastLast
Results 361 to 370 of 1047
  1. #361
    194 Post(s)
    Is the bolt broken below the surface of the thread?
    If it's not then just weld a nut to it and undo it. Even if its snapped flush you can still weld something to it.
    The image from the camera has it flush with the block, but I will see tomorrow morning when I get the plates apart.
    194 Post(s)
    Good points Darren, I asked about the 240V corded versions and they were close to $700 each! I am sure it will get used, but they were all around this 280-325 mark, so just went with the brand i had batteries for.
    MudRunnerTD (1st June 2020)
  5. #363
    They are great for tradies doing rough ins on new houses!
  6. The Following User Says Thank You to Winnie For This Useful Post:
    PeeBee (1st June 2020)
  7. #364
    Jun 2018
    24 Post(s)
    This Stanley ratcheting screw driver is great. I bought it because the hex sized screwdriver and Allen head bits fit into it. I wanted something that had greater reach and was easier to do up or undo Allen key bolts.
    There are two sizes, short and long and it was only once I used it I found that the long extension is removable! So you effectively get the short version too. Bonus.
    There are bits in the handle, but I've rarely used them.
    Highly recommended of you hate removing and resetting Allen keys to tighten or remove bolts.
  8. The Following 3 Users Say Thank You to Cremulator For This Useful Post:
    0-TJ-0 (3rd June 2020), PeeBee (3rd June 2020), rusty_nail (3rd June 2020)
  9. #365
    Just seen this circ saw on Maine cabin masters!!! What a bloody beast! For those not Familiar with stupid imperial, the blade diameter is over 413mm!!!
  10. #366
    109 Post(s)
    What would be the cutting depth on that one nicco?
  11. #367
    Probably around 180mm? I reckon it would still cut deeper than a 12" dropsaw
  12. #368
    109 Post(s)
    Would wanna be Japanese Makita too, not from the chinese division.
  13. The Following User Says Thank You to Plasnart For This Useful Post:
    rusty_nail (4th June 2020)
  14. #369
    They have stuff mate in England too! My 18v planer is English made. The Japanese stuff is definitely better quality than the Chinese tools
  15. #370
    109 Post(s)
    Wow didn't know about the pommy factory. Have always preferred makita tools, and when i bought the rattle gun a few years ago I had to be particular. The good from Nippon. The not-so-good from Bat Soup central.
