Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: 33's 3 litre CRD
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Quote Originally Posted by stevemc181 View Post
    Awesome to know, If you could post up a pic of your flap mod that would be great
    No Jax tyres in WA unfortunately.
    Here you go, no castor correction or scrubbing.
    Basically I made a small cut in the mudflap to slip it behind the bracket and put the screw in from behind.
    Gap on full lock.
    Jack
  2. The Following 2 Users Say Thank You to jack For This Useful Post:
    stevemc181 (17th January 2017), Vuck Roger (18th January 2017)
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Quote Originally Posted by Apollofish View Post
    Thanks for the pics, I'll see how she goes once I've got the new rubber fitted and do similar if it needs it.
  5. #23
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    Gap on full lock.
    Have you had the castor correction done, if not how is the handling with 33's on?
    2012 GU8
  6. #24
    Ballarat Area
    25 Post(s)
    Quote Originally Posted by rusty00 View Post
    Hello, no castor correction and handles fine.
    Jack
  7. The Following User Says Thank You to jack For This Useful Post:
    rusty00 (22nd January 2017)
  8. #25
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I'll have to mod the mud flaps. Had the 33's fitted yesterday on the factory +10 offset, 17" alloys, and she rubs on full lock. I've just removed them for now and will have a look at it on the weekend.
  9. #26
    461 Post(s)
    Two options. Remove the front mudflaps, or mod them. Or buy 10mm radius arm spacers. This will push the front axle 10mm forward. Id rather this over offset bushes any day. Plus cheaper and easier to fit.
    stevemc181 (1st February 2017)
  11. #27
    Legendary happygu's Avatar
    It doesn't take too long for the rubber to wear down a little ... no more rubbing after that, till you put new tyres on again
  12. The Following User Says Thank You to happygu For This Useful Post:
