27th July 2017, 09:31 AM
Patrol Guru
Spares for Trip
Hi All,
Doing a 10 day trip shortly reasonably remote but still passing through some towns and looking at what spares I should have with me. TD42Ti
- Radiator hoses, should I be using geniune or are aftermarket ok?
- Heater hoses?
- Coolant, looking through my service history it has geniune coolant in it now, is it only available from dealerships?
- belts? Geniune or aftermarket?
- Standard Oil, PS Fluid, Brake Fluid, Clutch fluid?
27th July 2017 09:31 AM
27th July 2017, 10:01 AM
Hoses , belts yeah but don't know anyone that carries heater hose as spare , silicone tape and or duct tape and metal repair putty , oils yes but if your carrying water anyway coolant may not be needed unless you're up in the high country .
Grease ,zip ties and wire also tyre repair kit and something to fix a leaking radiator .
Sometimes if you get carried away your spares can take up more room than your gear almost .
Making sure you get your 4by checked out thoroughly before the trip will help but the unexpected can sometimes happen for example my injector pump decided to leak in the middle of nowhere .
Heard many stories of air compressors failing but who carries spares or an extra pump , stick to the basics because you won't be far from help by the sound of it .
27th July 2017, 02:53 PM
1ltr bottle of Jack Daniels
The Following 3 Users Say Thank You to Avo For This Useful Post:
Clunk (27th July 2017), GQtdauto (27th July 2017), gubigfish (27th July 2017)
27th July 2017, 03:13 PM
Dribble Master
Avo
Bwahahahahaha I don't know why but I find that most amusing
The Following User Says Thank You to Clunk For This Useful Post:
27th July 2017, 03:33 PM
I'd take water > coolant. It'll get you out of the poo, and can be used for drinking/survival if the need comes.
27th July 2017, 03:46 PM
Avo
Only 1 bottle for 10 days ????????
27th July 2017, 04:06 PM
gaddy
That's a 100 ml per day , oh yeah I see your point !
27th July 2017, 04:07 PM
#8
It would be easy for Toyota owners , Tampons , Lippy etc .
The Following User Says Thank You to GQtdauto For This Useful Post:
27th July 2017, 05:06 PM
#9
Clunk
is that because lAST TIME I FOLLOWED HIM I BUSTED MY BOTTLES ON THE TRACK.......yes
27th July 2017, 05:07 PM
#10
gaddy
only 1 bottle for 10 days ????????
Sent from my sm-g900i using tapatalk
thats the spare..lol
The Following User Says Thank You to Avo For This Useful Post:
