7th September 2016, 02:58 PM
Enjoying the trips
Starting woes
Got a bit of a yarn to share, might save another here a little time.
Our TD4.2Ti was having a little trouble starting, then it cleared itself and all was good. But while a long way from home it started playing up again.
When cold I use the glow plugs, waiting to hear the relay open (not watch the dash light go off) and hit the key with immediate start. Hot, just hit the key and immediate start. Ran sweet and also good economy too.
What it started doing was take a bit of turning over before it would fire then run as sweet as.
Sometimes cold it would do this sometimes not, same hot, it was hit and miss. What it seemed like was the fuel needed to be pumped to the injectors as if they had leaked.
Swapped the fuel filters and they were quite clean (about 9000klm). Cut them open for a good look and no sign of water either.
There is a sensor in the thermostat housing that is part of the glow plug control, from the manual info it seemed to be OK.
The glow plugs draw 72amps, thought that would be good enough. But it was suggested I make sure all of them were working, so removed the connecting strip and they all read about 1.0 ohm. Which at 12VDC is 12amps each x 6 = the 72amps... correct.
I put Diesel Care through it hoping a bit of crud had formed on / in the injectors, not in there long so no change.
Tried a second negative to the motor direct, swear it improved but not for long.
Was thinking pump or injectors and feared the cost of such an exercise, there was no way of testing these on the car so they had to be removed.
On Monday morning it was really sluggish to start, so checked the battery which is a 10 month old Optima Yellow Top. My 1950's tester read high on the good side of the meter.... It has to be the starter cables or motor?
The cables looked good and the infra-red thermometer showed no increase in temperature at the lugs so off to the Auto Sparky we go.
He listened to my story and said I had eliminated all but the starter, well it had "one too may swims" it was shot, so corroded that the brushes had seized in their holders, bearings had seized and it had badly corroded the rest of the inside. He was surprised it still worked and said it would have a total fail any time.
Very relieved it didn't happen while in isolated areas on our own recently.
A new Hitachi starter is now kicking it into life as it used to, nothing to do with the fuel system at all!
Hope this helps if you have similar symptoms.
Cheers Macca
Edit, the car was taken to 2 diesel specialists, neither suggested the starter. But sent me away to check other parts of the system which eliminated them.
Macca
The Following 12 Users Say Thank You to macca For This Useful Post:
4bye4 (7th September 2016), Cuppa (7th September 2016), DX grunt (9th September 2016), GUtsy ute (9th September 2016), jack (8th September 2016), juzzs8 (7th September 2016), mudski (7th September 2016), Rock Trol (8th September 2016), Sir Roofy (7th September 2016), threedogs (7th September 2016), Touses (7th September 2016), Wizard52 (11th September 2016)
7th September 2016 02:58 PM
7th September 2016, 03:50 PM
theres one for the memory bank after you have finished bashing your head against the wall
OOI was the stater polling like a petrol with retarded ignition {symtom}
7th September 2016, 03:56 PM
Enjoying the trips
threedogs
Not sure what you are asking.
As the car always started instantly I have no idea what the starter motor sounded like when it ran on a bit.
To me (and the mechanics too I guess) it sounded OK, but was not spinning fast enough as it turns out.
Of course now it starts immediately so only makes the original sound.
Macca
7th September 2016, 03:59 PM
Ok make a bit more sense now over time you hadnt notice it turning slower
and why would you. must spin like a top now
7th September 2016, 05:12 PM
Enjoying the trips
Funny thing TD it was OK then it wasn't, certainly not a gradual deterioration.
The noise now is like a sneeze, ( need your imagination LOL) one sneeze and the engine is running.
A mate had a 47 Troopy, man that thing took some starting and the sky blackened when it finally fired.
My starter sounded like his grinding away until it finally fired whirr whirr whirr whirr whirr then it started now one whirr.
My Engrish is terrible today HAHA If nothing else I hope to give you a laugh
Macca
7th September 2016, 05:14 PM
The 747
Your mate's Troopy probably has an air leak in the fuel line. My Patrol does and it is the same. Takes a fair bit of cranking and when it does go it coughs and splutters for a little while and blows a crap load of smoke... kinda embarrassing lol.
7th September 2016, 05:22 PM
Enjoying the trips
Winnie
That's what it did Winnie, don't think his "new" 40 does it but Roofy would know as he was in the desert with him.
First time I saw the 47 start it was parked in front of a double garage, it filled it with smoke so much the interior disappeared. We were about to head off on a 7500klm trip with him WTF?
Macca
8th September 2016, 01:38 PM
#8
Enjoying the trips
A bloke who has a car the same as mine sent this;
[Exactly the same happened to mine, replaced so much stuff (glow plugs, injectors, relays and wiring) until I noticed everytime I hit the starter it dragged the battery down to 9v with a stuffed brush, rebuilt it and good to go!!]
Nearly headed that way myself!
Macca
The Following 2 Users Say Thank You to macca For This Useful Post:
Plasnart (8th September 2016), Rossco (8th September 2016)
8th September 2016, 04:53 PM
#9
macca
Yeah it was still pumping it out a bit on startup. Think it's a 40 thing my old shorty 40 series was absolutely shocking had a rebuilt motor in it too. Come to think of it think most 2H and B diesels I've seen carry on the same. .
The Following User Says Thank You to Rossco For This Useful Post:
macca (8th September 2016)
8th September 2016, 07:15 PM
#10
Enjoying the trips
Rossco
Of course you were out there too, apologies Rossco.
Macca
