17th March 2018, 08:44 PM
17th March 2018 08:44 PM
17th March 2018, 09:08 PM
Is it necessary to have the cover on? No
Will the seal on the bonnet for scoop be adequate? Yes if it is not damaged
Will the seal be able to withstand the heat from direcr contact with the intercooler? Yes
Hope that helps
17th March 2018, 10:52 PM
4bye4
Hope that helps
Sure does help 4bye4
Now another newbie question
Seems the pipes on the new intercooler are slightly fatter then the factory ones. Any tips to get the hoses on?
17th March 2018, 11:00 PM
simple83
Assuming it is the correct IC then either the manufacturer should have the correct fittings. Supercheap have various sizes and lengths. Make sure you have good quality clamps and they are firm as blowing a hose is exciting with sound and performance and EGT’s if you have a gauge. I found I could only use silicon hose a couple of times before renewing or it would blow out from under the clamps.
