20th January 2018, 03:02 PM
Fridge Slide
I am considering a fridge slide for the GU.
I don't have drawers and was wondering what the best way to mount the slider would be?
Has anyone done this that could share their solution, pics welcome
20th January 2018 03:02 PM
20th January 2018, 06:03 PM
Moderator
Tek screws straight through the floor.
Check out my Toy -->
Rogue Dung Beetle
GQtdauto (23rd January 2018)
20th January 2018, 06:12 PM
Administrator
Christ Dazz you dodgy bastard lol
Use the existing bolt holes from the dickie seat to mount a board to the entire rear floor and mount slide to that.
The Following 3 Users Say Thank You to AB For This Useful Post:
Rossco (23rd January 2018), Winnie (21st January 2018), Yeti's Beast (23rd January 2018)
20th January 2018, 06:23 PM
The 747
AB
Yeah this is what I would do.
Don't do what Daz does!
20th January 2018, 06:40 PM
Dribble Master
AB
Yep, makes it easier to remove the whole lot when ya don't need it in there
21st January 2018, 12:59 AM
I will work on the false floor tomorrow... thanks for the suggestions.
23rd January 2018, 08:52 AM
Hey guys. Dad got an old back seat from the wreckers and ripped the seat off the base and then bolted his slide to the base.
The Following 2 Users Say Thank You to Kevrana For This Useful Post:
AB (23rd January 2018), GQtdauto (23rd January 2018)
23rd January 2018, 03:07 PM
Moderator
AB
Winnie
Nah no way. Tek screws straight through the carpet and through the floor. works fine. no stuffing around. every mount hole gets a tek screw. Strong and fast and efficient. If you ever remove the slide the carpet will hide the small holes.
Both cars have drawers held down like this. Fridge slide straight through the floor too. no problem.
Anything else you mount into your car is held with tek screws?? Compressors, etc. Tek Screws get it done no dramas
Rogue Dung Beetle
23rd January 2018, 08:55 PM
MudRunnerTD
Really, my drawers before new cab were tek screwed down and felt pretty dodgey about it. New setup is bolted through floor with nuts bolts & big washers same with fridge slide. Not that you ever want it to happen but if the car ends up upside down don't know if I would trust tek screws to hold everything somewhat together. Guess its no different to having something loose in the cargo area tho just reckon if your going to do it may as well do it right for big items anyway. Did try and use existing captive nuts for tie down points and seats but just didn't quite line up well enough. . .
23rd January 2018, 09:45 PM
These Rivnuts are handy as a half way measure blokes. https://www.bunnings.com.au/kincrome...t-kit_p5910346
Also gives you a chance to prime/paint coat the steel hole edges before inserting/installing them from the top only needed. No doubt good bolts/nuts and big fender washers for the win though!
