30th October 2016, 11:50 AM
#1701
AB
Never ending...lol
Word from the wise is that the gear on the vac pump is pressed so I have to feed oil to it.
Back to a pirtek Monday for another custom fitting.
Just when you think you're sorted...
Oh bugger that sux. . Oh well it'll get there.
Sent from my SM-T800 using Tapatalk
30th October 2016 11:50 AM
30th October 2016, 05:36 PM
#1702
Administrator
Rossco
Kind of glad we didn't put the engine in yesterday though as I need to get that line worked out which is much easier outside the engine bay.
Got a bit bored today so flushed the radiator whilst it was out and cleaned everything.
Amazing how I thought my radiator was so clean but the bottom 1/4 was pretty caked with mud inside the fins.
Rossco (30th October 2016)
30th October 2016, 05:53 PM
#1703
Administrator
8:59 pm Fri 28 Oct
Sunshine West, VIC
Ooowww, hit Sunshine West, Vic Friday night, does that mean I'll 100% get this tomorrow?
Would be good to get this on Monday, work out exact length zip over to Pirtek in Bayswater before they shut to get the custom oil feed done and install engine Tuesday!
The Following 7 Users Say Thank You to AB For This Useful Post:
gubigfish (31st October 2016), Maxhead (30th October 2016), MB (30th October 2016), MudRunnerTD (30th October 2016), Rossco (30th October 2016), rusty_nail (30th October 2016), Sir Roofy (30th October 2016)
30th October 2016, 10:09 PM
#1704
The 747
AB
8:59 pm Fri 28 Oct
Sunshine West, VIC
I would never say 100% with couriers... Ever!
But it's a bloody good sign!
31st October 2016, 11:01 AM
#1705
Administrator
Winnie
Bugger, won't be here until Wednesday because of Melbourne Cup tomorrow.
Won't even let me go to Sunshine to pick it up from the depot.
31st October 2016, 06:48 PM
#1706
Administrator
When Bennys vac pump turns up I'm going to have to set it up properly as the gear is pressed so if I hook it up properly with the gear spinning, creating vacuum and oil feeding I'm not going to be able to simply block the vacuum line am I?
Blocking the vac line will surely cause issues?
The Following 2 Users Say Thank You to AB For This Useful Post:
MB (31st October 2016), Woof (31st October 2016)
31st October 2016, 07:34 PM
#1707
Administrator
Benny is going to be more shitty then me
31st October 2016, 07:58 PM
#1708
Block it. Its only vacuum. but the insides do need to be lubricated.
AB (31st October 2016), MB (31st October 2016)
31st October 2016, 08:00 PM
#1709
I stand corrected, apologies AB :-(
31st October 2016, 08:04 PM
#1710
Administrator
MB
All good mate, I was thinking the same restricting vacuum causing built up pressure, restriction, etc...
Thanks Matty!
