29th October 2016, 01:20 PM
#1691
Administrator
nissannewby
Why was that cover not supplied with the engine?
I don't know... They must've forgotten when they took pump out. They have it there just gotta get it now.
Stropp (29th October 2016)
29th October 2016 01:20 PM
29th October 2016, 05:32 PM
#1692
Administrator
So close!!!
Clutch done as well..
Just need vac pump and gear cover plate!!!
gubigfish (29th October 2016)
29th October 2016, 05:50 PM
#1693
Smart like tractor
AB
So close!!!
Did any oil feed hose for the vac pump come with that motor?
96 GQ coil/Cab
08 G6eT
29th October 2016, 06:01 PM
#1694
Administrator
Ben-e-boy
No mate but I've just blocked the feed for now and will just bolt your vac pump up for now simply to block that hole with no gear.
29th October 2016, 06:35 PM
#1695
Smart like tractor
AB
Could you use the old oil line from your original setup,
96 GQ coil/Cab
08 G6eT
29th October 2016, 06:59 PM
#1696
Administrator
Ben-e-boy
Nah the port is a long way from the pump. You can easily MacGyver something up though.
29th October 2016, 08:51 PM
#1697
Administrator
Never ending...lol
Word from the wise is that the gear on the vac pump is pressed so I have to feed oil to it.
Back to a pirtek Monday for another custom fitting.
Just when you think you're sorted...
29th October 2016, 09:56 PM
#1698
It's all great experience old mate, positive perception is the key to life ;-) !
You'll be able to strip down a 4.2TD from hands on memory like the QLDers in the middle of nowhere after all this ;-) !
The Following 3 Users Say Thank You to MB For This Useful Post:
AB (29th October 2016), MudRunnerTD (29th October 2016), Stropp (31st October 2016)
30th October 2016, 11:33 AM
#1699
AB
That's unreal !!! You learn something everyday , bugger me 😝
30th October 2016, 11:43 AM
#1700
And Auspost SHIT ME !!!! When we used to load Auspost out of Brisbane for Melb we had to overnight it or we would get deductions on the load payment , from (hazy ) memory anything over 19hrs penalties would start for each hr over . But now if i order parts & get delivery through them it takes 3-4 days so it seems it takes a long time for the courier to pick it up in Brisbane and take it to the depot and the same down this end 😤
