2nd November 2020, 07:49 AM
2000 gu td42t querry
Hey guys hope you can help here
I am trying to find out if a stock ht 18 turbo on a stock 2000 gu td42t has factory water cooled lines as i know it has factory oil lines are plumbed to the block .I just cant find information on the water lines.
Also this stock turbo and engine has 320000klms on it and there is zero blow by and the set up has been tuned with the factory 11mm pump with a large cross country inter cooler and makes 134 HP with max boost set at 16PSI . Question is it due for a new turbo ? And what would you replace it with to suit the manifold and dump pipe ( it has a Roo systems 3 inch exhaust , patrol docta air box and 4 inch snorkel ) to make a little more boost.
I cant inspect the car in person yet to visually see if it has water cooled lines or not.
Help really appreciated.
NO HILL TO STEEP
NO RUT TO DEEP
2nd November 2020 07:49 AM
2nd November 2020, 11:51 AM
I think they removed the cooling lines when the TD42Ti was introduced.
I replaced my HT18 with a 16G Mamba but you won’t get full benefit without better exhaust and air box.
John
12th November 2020, 08:31 PM
jff45
I think they removed the cooling lines when the TD42Ti was introduced....
That's correct. A 2000 GU TD42T would have had the turbo cooling lines when it left the factory.
