12th September 2016, 07:36 PM
#6961
Bitumen Burner
Winnie
Rossco, please don't!
Remember, Winnie.....Words not pictures, words not pictures. PML
The Following 3 Users Say Thank You to DX grunt For This Useful Post:
BigRAWesty (12th September 2016), Plasnart (13th September 2016), Woof (12th September 2016)
12th September 2016 07:36 PM
12th September 2016, 09:36 PM
#6962
SPAMINATOR
threedogs
Doof doof doof doof doof doof doof you animal ohh yeah doof doof doof
A little bit more $$ and you couldve had an Andriod double din set up
for what reason I have no idea why
Not much chop with an iOS device
The Following User Says Thank You to growler2058 For This Useful Post:
Kimbo63 (12th September 2016)
12th September 2016, 09:50 PM
#6963
Smart like tractor
bigguwesty
1450 front and 1350 rear.
And no idea on shims / valves went in.
I can ask if your interested.
Yes that would be good aswell as springs
96 GQ coil/Cab
08 G6eT
12th September 2016, 10:04 PM
#6964
Ben-e-boy
The specs on shocks are unavailable.
But have gone medium rate 2" front and standard rear 3" spring.
12th September 2016, 10:34 PM
#6965
bigguwesty
What is "medium" and "standard" rate?
13th September 2016, 06:50 AM
#6966
nissannewby
That's just what they call em.
They are to suit the weights above.
13th September 2016, 10:34 AM
#6967
threedogs
were you able to treat any unpainted surfaces or didnt bother about it?
I didn't have time. I stupidly decided to do this when I was supposed to be going out and forgot about the going out bit. SO it was all put back together in a rush. Once the weather dries out and warms up I will do it when I do the other side.
BigRAWesty (13th September 2016), Kimbo63 (13th September 2016)
13th September 2016, 10:54 AM
#6968
mudski
Grap some photos if you remember mate also it pays to remove the bottom guard bolts and levering out the guards when washing out the mud between the guard and cab nasty trap in there and the drain is a flat square hole gets blocked too easy
The Following User Says Thank You to Kimbo63 For This Useful Post:
mudski (13th September 2016)
13th September 2016, 11:52 AM
#6969
Kimbo63
On my other 4x4 it was important to remove the rubber bungs under the doors.
is it the same for Patrols , or just push a stick up the drain hole to make sure
they are not blocked ???lol
13th September 2016, 12:01 PM
#6970
threedogs
Haven't found a problem with build up in the doors the seals around the Windows seems to do a good job keeping the crap out TD
