Page 1146 of 1450 FirstFirst ... 14664610461096113611441145114611471148115611961246 ... LastLast
Results 11,451 to 11,460 of 14491
  1. #11451
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Yep. No money or a ruler, complete failure as a man
    I have 12 inches but I don't use it as a rule !
    472 Post(s)
    For real mate? You lucky prick!
    Did you know that condoms now have expiry dates printed on the latex!
  4. The Following 2 Users Say Thank You to MB For This Useful Post:
    GQtdauto (14th May 2018), Plasnart (14th May 2018)
  5. #11453
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Wow, how did you know that cock?
    Hmmmm...lol
    ________________________
    ______ 2017 D-Max _______
  6. The Following 2 Users Say Thank You to Maxhead For This Useful Post:
    GQtdauto (14th May 2018), growler2058 (14th May 2018)
  7. #11454
    472 Post(s)
    I didn’t mate! Never been able to roll one back far enough to prove but apparently old mate can? Tall tales being told me thinks :-)
  9. #11455
    Feb 2011
    Shed
    45 Post(s)
    Sh1t #$%$# pissed me off today............................................. ............................................Actual ly every pharkn day
  10. #11456
    Dec 2016
    Northeast Victoria
    41 Post(s)
    In school they called me the pink jelly bean
  11. The Following User Says Thank You to GQtdauto For This Useful Post:
  12. #11457
    May 2016
    lower west victoria
    30 Post(s)
    That's the way mate, hold your head up high and be proud of who you are. It's blokes like you that make the rest of us feel adequate ;-)
  13. The Following User Says Thank You to 10G For This Useful Post:
    GQtdauto (16th May 2018)
  14. #11458
    43 Post(s)
    Soooooooo.
    Head come off today.
    Tests confirmed it was gas in coolent.
    Gasket looks ok.
    So heads off to be pressure tested and crack tested.
    Exhaust manifold warped and egr pipe had a hairline crack in it too...
    On an up side the pistons and bores look great, glow plugs are great and no sign of bad injection spray....
    But still pissed.
    103*** on it..
    Think itll be up for sale once fixed....
    Soooooooo.
    Gasket looks ok.
    But still pissed.
    103*** on it..
    What's next then, a nice D4D Prado?
  16. The Following User Says Thank You to Clunk For This Useful Post:
  17. #11460
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Soooooooo.
    Gasket looks ok.
    But still pissed.
    103*** on it..
    Kallen, share your sorrow, mine not quite as crap.
    Last week, trip up to ecpt to attend to needs of myCRD, fit procharge stage 3 turbo to replace stock, as squeal noise happening and thought it was comp whl against housing. Took along new exhaust manifold gasket for install as so far in anyway.
    Yeh, exhaust manifold shield hx hd bolt rounded off trying to remove, running out of shop time so left manifold as looking ok. Installed turbo and fired it up and bugrrrr noise still there, strip down again (2 failed exhaust manifold studs) easy out the broken studs and 3mm machine off mating face, then all back together again $$$$$$. And cracked egr pipe, but mine blocked both ends..HaHa
    Need more work to achieve improved low down torque (Big exhaust wheel bit laggy low down).
    Hey do you know what the CRD stock turbo actuator inches of mercury (vac) to hold lever up against stop? , doing adjustment to actuator rod length (reducing) to keep veins closed longer to bring spool and boost on around 1800-1900rpm, Getting improvements as I play with actuator, boost 21psi @ 2000 rpm, max B 23psi @ 2250rpm / max 150rwhp & 370 N-m. Posted up story on ZD warriors but no feedback yet...
