4th May 2016, 08:13 AM
#6461
The 747
GQJETT
Great thanks mate. Upgrading my brakes is definitely on my to do list. Let us know how they perform compared to your old ones.
I bought calipers from a TB42E GQ, they are twin piston and are a massive upgrade to the single pistons!!
4th May 2016 08:13 AM
4th May 2016, 08:14 AM
#6462
I'm not sure
mudski
Get some GU diffs under it and then you'll have GU brakes. And a slightly wider stance.
I'll have to look into it. Are the GU brakes much better than the series 2 GQ brakes?
4th May 2016, 08:56 AM
#6463
GQJETT
I think there a bigger disk.
I know the 4.8 brakes are and later gu's are as you can only fit a 16" rim on them..
Pretty sure early gu's are similar to the series 2 gq as you can still throw 15" rims on em..
If your doing the gu upgrade it's best to grab the master cylinder aswell.
And while your at it the steering box and drag rod aswell.. (drag rod will be needed regardless due to the longer distance from box to hub..)
4th May 2016, 09:30 PM
#6464
I'm not sure
bigguwesty
Sounds as though it could quickly turn into an expensive project haha! I was thinking about fitting a PID Diesel Hydro Boost kit. I wonder if that would be comparable?
4th May 2016, 09:38 PM
#6465
GQJETT
Hydraulic is an awesome upgrade. Probably ultimate..
Safe brake do a nice braided line upgrade which the boys say adds a nice positive feel to the pedal..
The Following User Says Thank You to BigRAWesty For This Useful Post:
4th May 2016, 10:11 PM
#6466
I'm not sure
bigguwesty
I've got one of their kits bookmarked actually, it's on the to do list. I think I'll save my pennies for the PID Hydro setup. I wonder if anyone on here has hitted the kit?
The Following User Says Thank You to Chappy For This Useful Post:
BigRAWesty (4th May 2016)
5th May 2016, 08:30 AM
#6467
I havent fitted one but have driven one. Pedal feel is much firmer but no issue locking up 4 35s on bitumen. Will out do any other mod but if you do the lot will have a very good braking system
The Following User Says Thank You to nissannewby For This Useful Post:
5th May 2016, 04:55 PM
#6468
Winnie
There is one of these sitting in the front yard around the corner from me , minus the motor.
Been there for years, whole family are Patrol crazy lol
From 306mm to 316 mm I wouldnt think 5mm would give a
huge benefit in braking,the twin piston caliper hell yeah
306 being most model and 316 being the 4.8s
6th May 2016, 10:32 AM
#6469
threedogs
It not just about disc size from the standard GU brakes to the TB48 brakes. The master cylinder has a larger bore and so do the pistons in the calipers. Doing this conversion on mine made a big difference to braking power.
6th May 2016, 07:02 PM
#6470
Patrol Guru
The Following 2 Users Say Thank You to sooty_10 For This Useful Post:
jay see (6th May 2016), mudski (6th May 2016)
