Page 377 of 566 FirstFirst ... 277327367375376377378379387427477 ... LastLast
Results 3,761 to 3,770 of 5660
  1. #3761
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    No Steve, I have a NASA BM1 battery monitor which counts amps in & out & shows real time amps in & out. (Uses a shunt). I wish this sort of phone technology had been available when I installed my set up. It would have far easier & saved me a bit of grief. How does the app calculate SoC? Do you have to input the battery size when setting it up?
    My Dual battery loads are connected via a Shunt to the BMV-702 so all loads in and out are measured. I am using a Lifepo4 battery which has around a 99%+ charge efficiency, so it's pretty accurate. The app simply recives the BMV data over bluetooth, so its not calculating anything, just displaying the data remotely. Yes, battery size needs to be input initially.
    Ballarat, Vic
    174 Post(s)
    The BMV-702 & app sounds like a good thing!
  4. #3763
    Jul 2013
    3 Post(s)
    A bag of frozen winter veges.
  5. #3764
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Yep, you'd need the BMV-702, and the VE-Direct BT Dongle, the app is free. Not cheap but Victron gear is top notch. I have the BMV-702 in my pillar pod, but its pretty ugly next to the redarc gauge, so I think I'll move it down the back somewhere and just use the app.
  6. #3765
    Just ordered a front Pro-locker. E-lockers are ok but I need a tank
    that will hold a bit of air. plus they both do the same thing anyway and leaves me extra $$$ for other projects
    Also brought a 3mt x 2mt wall for my awning, keep a bit of weather out if I dont take my camper.
    Now to strip the tank out of the other 4x4 been meaning on doing it for months now. Nice big tank
    that will allow me to run air tools if I decide to go that way
  7. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    jay see (27th May 2017), Rossco (27th May 2017), stevemc181 (24th May 2017)
  8. #3766
    22 Post(s)
    New sump gasket, head gasket and ARP head studs.
    96 GQ coil/Cab
    08 G6eT
  9. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    gaddy (26th May 2017)
  10. #3767
    sounds like you're doing it once and doing it right,
    you must be hanging to crank this motor over.
  11. #3768
    Jul 2015
    Camden NSW
    6 Post(s)
    Picked up a bargain on a Sony 55"HD Smart TV for the spare room. A two week old current model demo. The shop was just starting to move a dozen or so demos to another wall, to fit more in. Sticker price was $1,499 I offered them $950 on the spot and they took it. Full warranty, not a mark on it. Wasn't even shopping for a TV. Right place, right time. The 4wd shows will look good on it.
  12. #3769
    49 Post(s)
    Haven't brought it yet but will need to get a bottom end bearing kit soon as the oil pressure isn't great, but considering the fact that the engine is pushing 1/2 a million Ks a freshen up is probably due.
  13. #3770
    49 Post(s)
    Again not today, but I think we have a thing for blue cars.
    My gu
    The wifes x5
    And my limited R8.
