12th September 2010, 10:16 PM
#21
G'day Kev,
Going by the symptoms you're describing I'm guessing you also own a 3l GU Patrol? A bit more information will make it easier for us to help you.
Tony
12th September 2010 10:16 PM
14th September 2010, 05:50 PM
#22
Thanks for than G- Unit ive got a mate making me one up ill put in in this weekend
23rd September 2010, 11:42 AM
#23
No problems mate.
I'm actually going to take the EGR probe thing out of the manifold on the weekend. I'm still getting an annoying whistling noise noise and it just HAS to be related to the EGR somehow.. I can't think of anything else, so this is the next step.
25th September 2010, 10:36 PM
#24
The reference document posted is outstanding thanks for the detail
7th October 2010, 10:54 PM
#25
I have blocked off my EGR, but i blocked it at the exhaust manifold end. Reason being, I thought it would reduce the heat being transfered along the EGR pipe. It may or may not make much differance.
8th October 2010, 06:34 AM
#26
Roady
It won’t make any difference. Most people just block it at the inlet manifold because it’s easier to do, but stopping the gas flow from anywhere does the trick and the alloy pipe from the valve to the inlet manifold no longer gets hot.
One advantage to blocking it at the inlet manifold is that you no longer get oil building up in the EGR valve.
8th October 2010, 02:22 PM
#27
Administrator
Stuck this thread, thanks Timbo.
10th October 2010, 04:11 PM
#28
in this case timbo your just stating its a better way of utilising the power earlier im just aboutm to go this to my 2.8 td GQ and ill let you know how I go
12th October 2010, 06:39 PM
#29
Hardcore
Hi Guys, If I happen to punch out a bunch of EGR blocking plates that slide in as described in the post above, would anyone be interested?,
cheers The Ferret.
The Following User Says Thank You to the ferret For This Useful Post:
sherman tank (27th June 2011)
12th October 2010, 10:28 PM
#30
Would be depending on what you make them out of.
Stainless is supposedly the best, been looking around to find some off scraps but so far haven't found any./
Paul
Western Patrol Club member #27
2.8TD GU --> The Red Rocket
![](image.php?s=d0d0590131b5cadadf9508699484e6e8&u=51&type=sigpic&dateline=1308038239)
