Page 73 of 74 FirstFirst ... 71727374 LastLast
Results 721 to 730 of 734
Thread: Jay see 1997 GU build up
  1. #721
    477 Post(s)
    @PeeBee Philstar, what would happen if @jaysee Brother installed a tyre valve in the cap instead of a breather and linked up his onboard air compressor to force water out of its lowest point gravity tube? Could the air pressure Archimedes style push every last droplet uphill to a comfortable collection height?
    Cremulator (23rd May 2024)
  3. #722
    197 Post(s)
    Yep, but the increase in pressure only needs to be a poofteenth to generate massive velocity out the nozzle ( 5PSI across the total area of the tank is a massive discharge force.). What I dont like about that idea , is the water jet is going to be very fast so more splashy and likely to waste more than say a steady stream via gravity, plus you need to switch it off pretty quickly as the pressure will build fast and get progressively worse - FAST.. I guess if you want to wash a car or similar the added velocity which will equate to volume is fine but for a billie fill or a quick wash of the hands , slow and steady would be my pick. I think I have mentioned before that Jenny and I burned thru 30L in two days at dalhousie because it was 28 deg and the springs well above that, and we didn't waste any, decanted it from a jerry with a hand pump. The electric pumps are a quick way to lose track of your fixed water storage in my view, but you know, its connected now, and there for a reason and choice, it works, get used to it I guess and see how it goes - easy to convert to gravity if it becomes a problem.
    Regards the discharge height, well my water tank hoses hand out the door and terminate about 8" off the ground so pot filling and hand washing is not too bad. - Just a comparison but maybe work considering also as pots are on stable ground as well instead of trying to do the octopus 5 arm shuffle.
  4. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (23rd May 2024), MB (22nd May 2024)
  5. #723
    477 Post(s)
    Apologies @jaysee
    Philstar, what if the air compressor (onboard always and needed offroad anyway) was permanently connected to a water tank with a basic pressure small lightweight valve/regulator? Of course the hose sump/outlet would need a severely reduced end on it with a valve/tap for water trickle if needed careful saving or high pressure squirting potential?
  6. #724
    No need to worry about it guys, no on board compressor..
  7. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (22nd May 2024), PeeBee (22nd May 2024)
  8. #725
    197 Post(s)
    Apologies @jaysee
    I would run a pressure regulator limited to no more than 5psi. Anything more and the tank could split. Running pressure in a plastic tank is asking for problems.
  9. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (22nd May 2024)
  10. #726
    477 Post(s)
    Apologies John Mate, I take full blame for bastardising temporarily your Build Thread Brother
    Pictorially, in sequence, I guess this is what I was trying to suggest to Philstar:
    The first three (3) photo examples are similar to what we use at work to connect to mains water garden hoses to vary between taking a trickle sip of water when thirsty in the yard to also carefully blasting truck radiators or full tilt mud blasting pinpoint out of their tipper corners at a long distance etc…
  11. #727
    197 Post(s)
    Yep, I get it, but NO, leave it as it is if you want the pump and pressure would be my recommendation.
  12. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (23rd May 2024)
  13. #728
    Well I've done it again.
    Electronics and me have a long battle before we're both on the same page. This time I brought a kickass battery monitor
    https://kickassproducts.com.au/produ...waAudQEALw_wcB
    It seems to look like I'm only going getting volts. I had a fridge and the freezer both on and compressor running on both when I took the picture and still showed just about no amps.
    Negative on the battery to -B on shunt and -P on shunt to ground (metal body)
    Have I got the -P side of the shunt correct?
  14. #729
    Well it looks like my rear bar isn't going to make the big trip. From a completion date of the 16th to the 18th to the latest today, it's still not finished. I went out and spent some.
    Main reason was to carry 2 Jerry cans, that's not going to happen so I went out today and updated my rack to carry the cans, a spare tyre, maxtraxs and what whatever else I what to throw up there.
    While out today picking up things all over the place I also got a bushwakka 270 awning.
    With eofy savings it was a good time to upgrade.
  15. The Following 4 Users Say Thank You to jay see For This Useful Post:
    10G (26th June 2024), BigRAWesty (25th June 2024), MB (26th June 2024), PeeBee (25th June 2024)
  16. #730
    Geeze that's going to be one very loaded roof!! Shame the bar isn't done though!!
