So the Y62 has front hydraulic height adjustment from factory but not rear?
No ir had HBMC Hydraulic Body Motion Control that is basically a Hydraulic sway bar system. The rear springs drop out but the front doesn't have the same range of motion and needs thebsystem to be depressurised to allow the front springs to be removed safely and then depressurised on completion.
The front also needs new Upper Control arms to increase front axle load rating adding 180kgs to the front for the bar and winch
I noticed yesterday that one of my HID driving lights has died. I pulled out the receipt for when I bought them in 2012. I installed them when the car was a week old. 12 years is not too bad. So I took the opportunity and bought a pair of these:
Bought a new 9hp engine for the Mobilco workhorse. The old Kohler 6 1/4 hp crank has slapped the con rod in half again (repaired 20 yrs back).
Should do the job.
