Page 567 of 568 FirstFirst ... 565566567568 LastLast
Results 5,661 to 5,670 of 5677
  1. #5661
    Put down a deposit for a Raslarr Rear bar for the 62, should have it early June. 50 bux i tell ya!!
    That's awesome man, I'll be able to use your rubbish bag on the Simpson trip!
  2. The Following 7 Users Say Thank You to Winnie For This Useful Post:
    10G (10th May 2024), AB (6th May 2024), BigRAWesty (18th May 2024), MudRunnerTD (6th May 2024), mudski (6th May 2024), Plasnart (5th May 2024), Stropp (5th May 2024)
  3. #5662
    331 Post(s)
    Bhahahahaha
    Just bought a Brake light switch for the Y62 as they are a known failure point and if it fails you can not start the car. While i was there a pair of inner and outer CV boots for the front and the back of the Y62 and 1 Bush for the control arms. All into the spares kit.
  4. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (6th May 2024), Stropp (7th May 2024)
  5. #5663
    May 2016
    lower west victoria
    30 Post(s)
    well, injector cleaner (petrol), llm spheerol grease for grease gun and start ya bastard.
    got some work on old mowers and old utes coming up.
    got a new foglight for the 'trol.
  6. #5664
    197 Post(s)
    4t jack stands and a set of deep 1/2" drive sockets
  7. #5665
    197 Post(s)
    Bought a new h/d Sutton Tapping wrench, finally destroyed 3 wrenches today in fast succession on the tapped holes of the antenna mount - poor man pays twice comes to mind! Also bought a set of the over-center canopy body kits to lock the canopy to the tray. There are bolts at the front and rear however the fronts were in shear, so after a close examination found I had built a set-up that was very difficult to impossible to replicate the rear bolts in tension.
    Stropp (13th May 2024)
  9. #5666
    197 Post(s)
    Jack stands arrived from Total Tools today - got the bellow from the front door - 'ITS YOURS AGAIN< TOO HEAVY, YOU SORT IT OUT - door slams - yep they are beauties, along with the magnetic deep throat 1/2" drive sockets - gotta love internet shopping!
  10. #5667
    197 Post(s)
    This brute arrived today. The original surviving HD tapping wrench is at the bottom. I like the extra leverage and everything is so much bigger and gruntier.
  11. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MudRunnerTD (17th May 2024), Stropp (18th May 2024)
  12. #5668
    Yea, Victoria
    Bought a 3/8 twist handle socket bar. Mostly for the bike but will likely be handy for lots of things.
  13. #5669
    331 Post(s)
    Is that a Ratchet Tap wrench? I Like it A Lot!!
    The tread boxes are nice. the Expedition 134 bloke really missed an opportunity to make a half size box like that. Very kool
  14. #5670
    331 Post(s)
    I Sold a Testicle and bought the Coil Delete Rear Airbag system for the 62 today, will have it by Next weekend. Then need to fit it then get the car over to Hastings for a few days for the front lift and Engineering for a 4000kg GVM Upgrade. I cant do the front lift at home as the HBMC Suspension system needs specialist equipment to bleed and re-charge the Hydraulics. Exciting times.
  15. The Following 10 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (18th May 2024), BrazilianY60 (18th May 2024), Cremulator (18th May 2024), jay see (18th May 2024), MB (17th May 2024), PeeBee (18th May 2024), Plasnart (18th May 2024), Rossco (12th June 2024), Stropp (18th May 2024), Touses (18th May 2024)
