12th May 2024, 02:47 PM
#14511
mudnut
With the sub-standard crap that comes with every second purchase, whether it be the wrong part, defective part, or just built wrongly, how does society still function?
Well!! My run of F@#K S%^ttery continues. Bought a brand new after market washer bottle from , Patrolapart, when I was in Melbourne. Went to install it today. I had already siliconed the two rubber seals and glued the motor housing to the bottle. Through past experience, I have found that the motors can pop out in rough conditions or if being jostled when changing a headlight. Which by the way, another brand new one has already got cracks in it and has moisture on the lens.
Any way, the motors are both leaking out the bottom, from inside. So I'm 380 ks from Lilydale stuck with two leaking bottles!!
12th May 2024 02:47 PM
13th May 2024, 01:46 PM
#14512
mudnut
Refitted the old washer bottle. On closer inspection, I found the exact defect in the bottom plastic casting on both new pumps, not the motor seal I suspected. I bet the whole batch is defective. Tried sealing both with silicone rubber. Only time will tell if it works.
13th May 2024, 02:27 PM
#14513
mudnut
Go back to PAP, they should warrant this Craig.
13th May 2024, 06:57 PM
#14514
PeeBee
760k round trip. I'm on it!! Actually went to ring them but they were at lunch. Will try tomorrow.
13th May 2024, 07:07 PM
#14515
If they will supply a replacement, I am happy to pick it up and post it to you, only 20 mins from me, not a problem.
The Following 3 Users Say Thank You to PeeBee For This Useful Post:
AB (13th May 2024), mudnut (13th May 2024), mudski (3rd June 2024)
13th May 2024, 08:00 PM
#14516
Administrator
PeeBee
Good onya Phil…
13th May 2024, 08:34 PM
#14517
Administrator
Test AB
13th May 2024, 09:38 PM
#14518
Getting database error on desktop but iPad opens up fine @AB
14th May 2024, 07:06 PM
#14519
I bought a low profile blood pressure monitor off the internet, so I could generate the historical for the doctors post the stent. Anyway the unit arrived, unwrapped the packaging and put it to the side for later use. Today I thought I would open it up, put it on charge and give it a whirl.
Well opened the box and no monitor or charge cable - ummmm, so searched the house in case I had hidden it from the gargoyle and nope, the box was delivered empty.
Now on the treadmill finding serial numbers, receipts, name of the neighbours cat and other equally important data to validate I have not sold the unit on gumtree for $5.
At least the response has been swift from the customer service department. I guess just another modern world issue!
15th May 2024, 09:21 AM
#14520
PeeBee
Update is the supplier is not the owner of the problem, they cant supply any service if they dont have the order number and thats even when OI supply the copy of their model number and serial nuber of the unit - WTF? Anyway the plot deepens as this parcel was opened by the Aust Customs for inspection and sealed back up. I suspect this is where the item disappeared - so who is liable for the theft or possibly the empty box? I have kicked this to touch, not worth the time chasing for thr dollar value but frustrating. I will be able to get a refund I think via Paypal, so thats something - still dont have the unit and wont re-order based on the attitude of the service rep - will buy elsewhere something different.
