6th May 2024, 09:20 PM
#701
I'm not sure how you tell, or if there is an inlet and outlet side to the pump, but in the 'features' screen grab you posted it states that it has a "Special valve for liquid input and output".
Maybe the hoses are hooked up the wrong way round and the valve is stopping the full flow?
6th May 2024 09:20 PM
6th May 2024, 09:34 PM
#702
Cremulator
I did try it both ways (briefly)and it seems to be the way I left it was the correct way, but I will definitely be checking everything again. I'm sure that with me rushing I've missed something simple..
The Following User Says Thank You to jay see For This Useful Post:
Cremulator (6th May 2024)
6th May 2024, 10:02 PM
#703
Breadmaker Shaker
I don’t mean to tell you how to suck eggs mate, but sometimes simple things are the cause. Are all hose joints air tight? There are no hose clamps at the pump connections in your photo.
![](image.php?s=22626448de5f5a7a04cabde2827e87dd&u=115&type=sigpic&dateline=1651651487)
6th May 2024, 10:13 PM
#704
Plasnart
All good mate.
I ran out of clamps and I wasn't go back to Bunnings for the 3rd time. I'll pick up a couple more on the way home during the week. They were a snug fit, but yeah they do need clamps..
6th May 2024, 10:49 PM
#705
Cremulator
I think this refers to the diaphragm valve inside the pump so it sucks in liquid and the valve closes then the diaphragm discharges against the closed seal, pretty normal, there will be a flow arrow on the pump and if connected with correct polarity it should work but its only self priming with a positive head on the inlet side i suspect. To improve operation a check valve could be mounted in the supply line from the tank to the pump so water does not siphon back away from the pump, pretty cheap way to resolve that, as jaysee said its going to be a simple fix.water
11th May 2024, 12:18 PM
#706
11th May 2024, 12:52 PM
#707
What about installing a 3-way control valve to switch between the feed from each end?
The Following User Says Thank You to Cremulator For This Useful Post:
11th May 2024, 08:48 PM
#708
Cremulator
I think I'm going to call the mob that I got it from and have a chat with them first.
A 3 way valve would probably work and that might be the way to go..
Thanks for the input..
Cremulator (11th May 2024)
11th May 2024, 11:25 PM
#709
What are you expecting or wanting to get from the tank and pump? Are you looking to fill a pot or use it for a quick shower or wash mud from a clogged radiator? I think this is the starting point in all honesty. Linking the hoses or running them singly will get you the same result as the inlet head is the same. You just achieve twice the volume to draw down. If you want a higher pressure then consider a small pressurised accumulator like they use in a boat water system. Like this one. I was going to use it on my radiator spray bar to even out the diaphragme pump pulse, but in the end it wasn't necessary.https://www.ebay.com.au/itm/18638198...FjSaNNYKBjw9sD
11th May 2024, 11:38 PM
#710
PeeBee
I'm happy with the flow and how it works, but I'm only getting the top part of the water out approx 20 lts with good flow, then it looks like it's sucking air.
