I'm pretty sure in the past I used a similar setup protecting a similar load and my main cct breaker was only 60 amps.
And as BrissieBoy said, keep all your fuses as close to the battery as possible.
I've changed the breaker to 60 amp and 5 amp fuses in the block (charging ports)except for the console fridge 10 amp and radio 10 amp as stated in the original car fuse.
