Results 1 to 10 of 13
Thread: 2012 CRD valve cover gasket.
    Yea, Victoria
    Hi all, is the CRD valve cover gasket prone to leaking? And since its rubber would torquing up the bolts that hold it onto the head be worth doing. And, if so whats the torque setting for these? Cheers all.
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    mine was leaking like crazy, i just replaced it
    the torque is 10-11nm, maybe loosen and re-torque?
    2008 CRD Auto Wagon
  4. The Following 4 Users Say Thank You to pollenface For This Useful Post:
    BrazilianY60 (7th September 2023), Coldcomfort (6th September 2023), growler2058 (7th September 2023), MudRunnerTD (17th October 2023)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    I don't know what newton meters are, but the foot-poundage is, like, 1.
    And yeah, criss-cross out from the centre when doing them up, maybe in a couple of stages. (Nip them up, then go back over them all, to final torque)
    Old rubber will get hard and perish. New gaskets probably aren't expensive but gasket-goo or dressing will give a bit extra mileage.
    1989 LWB 5-Seat, TD42
  6. The Following 2 Users Say Thank You to mihit For This Useful Post:
    Coldcomfort (7th September 2023), growler2058 (7th September 2023)
  7. #4
    Yea, Victoria
    Thanks guys. I'm toying with the idea of lifting the valve cover and replacing the rubber gasket. I have new glow plug seals and have ordered a set of new glow plugs today. If re-torquing works thats good. But if not I will bite the bullet and do the valve cover lifting thing. I only got the glow plugs because if I have to remove them I may as well replace them. They are working fine but with 250K of service they may not survive being tampered with. I also bought a workshop manual today. Should have done that ages ago.
  8. The Following User Says Thank You to Coldcomfort For This Useful Post:
  9. #5
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Quote Originally Posted by mihit View Post
    FYI:
    10NM = 7.4 ft-lbs
    11NM = 8.1 ft-lbs
  10. #6
    Yea, Victoria
    That's what professor google told me as well.
  11. #7
    Nov 2019
    Perth
    5 Post(s)
    I'd replace the glow plugs while it's apart, they're cheap, you've gotten your moneys worth out of them.
    2008 CRD Auto Wagon
  12. #8
    Yea, Victoria
    The plan is to re-torque the rocker/valve cover this weekend. Shouldn't take too much time and if all goes to plan the glow plugs and seals will also get replaced. Although the glow plug thing will depend on how much time I have left.
  13. #9
    Yea, Victoria
    I had a good look at my valve cover and its surrounds. I discovered that you cant re-torque the cover bolts with out first removing the injector tubes. That's not gunna happen any time soon. But with a good light I think that I have discovered the source of my oil leak. I'm pretty sure that its the rear (number 4) injector seal. I don't know if its very clear in the pictures but I've put them in anyway. Looks like its a new valve cover for me.
  14. #10
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Yep. That sucks. I had a mobile mechanic mate of mine bodge number 1 up a couple of years ago due to the cost of a new valve cover. He is an ex Yota tech, but their black goo is awesome. Have had no further leaks since he did that. Will have to reach out to my Dhuck charity at some stage and replace it.
