Results 1 to 10 of 19
Thread: Power loss
    May 2023
    Power loss
    Good evening all I have a GQ RB30 carby rig driving it seems to lack power takes a long time to get any speed up and drops back to around 70 going up any hills
    Starts and idles great has extractors 2 1/2 inch exhaust plugs seem fine all set to 0.9 mm fuel pumps good sits at 30 psi revs free at stop no missing compression is all around 165psi cold just stumped on what it could be any help would be helpfull
    Cheers in advance
  2. The Following User Says Thank You to Fouldsy67 For This Useful Post:
    MB (7th May 2023)
    Quote Originally Posted by Fouldsy67 View Post
    Cheers in advance
    Have a look at this thread. There is quite a bit of info about the carby in it. I found the second stage butterfly was sticking or not opening properly. http://www.nissanpatrol.com.au/forum...-Helpful-Hints
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    manual? auto? (clutch slip? TC issue?)
    1989 LWB 5-Seat, TD42
    May 2023
    Manual and just found a box in the back with 3 carbys in it clutch is good no slipping there
    The carbies playing up is a common thing for these old buses. I've been on the lookout for a spare carby so I can put a kit in it and keep it for long trips in remote areas.
    Beginner Big Girl's Avatar
    Feb 2022
    Perth
    Same problem, diesel 3L GU 2004. It seems to know when it's close to home and does it on the same hill every time! On the third MAF sensor. New air filter and thorough clean of the intake. She will be coasting along fine then suddenly loses a little power, like she is suddenly driving into the wind. And she does it constantly when towing the caravan! Any ideas welcome. No we haven't done a diagnostic, that's next.
    465 Post(s)
    Quote Originally Posted by Big Girl View Post
    Possibly a boost leak. Are you running the original intercooler?
  10. #8
    Feb 2022
    Perth
    Yes. Had the head replaced last year. Will contact the shop and book her in for diagnostics. What are your thoughts?
  11. #9
    465 Post(s)
    Well if you are running the original intercooler, I would say its leaking. Check the underside of the cooler. Is is clean? Or does it have oil deposits on it.
  12. #10
    Feb 2022
    Perth
    Thanks heaps Mudski, much appreciated. I did some research and will get under the bonnet this afternoon. Regards, Louise
  13. The Following User Says Thank You to Big Girl For This Useful Post:
    mudski (9th May 2023)
