1st February 2023, 09:54 PM
#11
Travelling Podologist
BillsGU
Or wait until it is dark and put a bright light under the car.
Ta, tried that a short time ago, The only light which shines through is through the white plastic clip holders set into the floor, & they are all watertight.
How can I tell if door seals are rooted & need replacing?
Vinyl flooring now dry & cab dry , so putting it all back together tomorrow hopefully.
1st February 2023 09:54 PM
2nd February 2023, 07:57 PM
#12
Wacky idea as usual, wondering if whilst the flooring is still out of the cab if filling the floor pans up with say 100mm deep of water through the closed doors windows could show the drips whereabouts coming out of? ![](http://s3.amazonaws.com/tapatalk-emoji/emoji23.png)
The Following 4 Users Say Thank You to MB For This Useful Post:
BrazilianY60 (2nd February 2023), Cremulator (2nd February 2023), Cuppa (3rd February 2023), Hodge (3rd February 2023)
2nd February 2023, 11:29 PM
#13
Patrol Guru
That is what thinking out of the box means, hahaha!
The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
Cuppa (3rd February 2023), MB (3rd February 2023)
3rd February 2023, 06:22 AM
#14
MB
I was thinking along the same lines , only close the doors and drive back into the river and mark the leak points, might result in slightly less water to clear up?
The Following 2 Users Say Thank You to PeeBee For This Useful Post:
Cuppa (3rd February 2023), MB (4th February 2023)
3rd February 2023, 02:52 PM
#15
Thanks embee, peebee & bee-razilian - legends! I need to use the car. All back together yesterday. Drove it for the first time this morning, not through any water & was relieved the strange sound I had heard as I was driving home from the dunking was no longer there. It was an odd sound coming from the rear of the car. Wasn't running water, but I now wonder if it was the filled chassis emptying & water maybe hitting the spinning prop shaft & being flung back upwards under the car. Have never heard it after other water crossings though.
Seems very obvious to me now that moving through water & stopping in water (at least more than momentarily) are very different events with different consequences.
The Following 5 Users Say Thank You to Cuppa For This Useful Post:
BrazilianY60 (3rd February 2023), MB (4th February 2023), mudnut (3rd February 2023), pearcey (3rd February 2023), PeeBee (3rd February 2023)
4th February 2023, 02:45 PM
#16
don't the doors have drains ? ... my gq will push water up these drains into the cab
The Following User Says Thank You to garett For This Useful Post:
5th February 2023, 09:50 AM
#17
I saw a video of a bloke looking for leaks and they used a smoke machine inside with doors and windows closed to find the leaks, worked well! Y
The Following User Says Thank You to Stropp For This Useful Post:
5th February 2023, 02:17 PM
#18
garett
Good point, mine certainly do. Wonder if that the reason there is the plastic sheet glued onto the door under the fabric/masonite door card?
6th February 2023, 08:17 PM
#19
