18th December 2022, 08:05 PM
Instant on glow plugs - how do they work?
Can someone explain to me the 'mechanics' of how these instant glow plug systems work? The 2.8 TD Nissan and the chev had /have the 6 sec glow process, whereas the latest model hilux and colorado at work you just turn the key and the motor fires. Is this a glow plug design or an injector pressure design thing - curious.
18th December 2022 08:05 PM
18th December 2022, 08:30 PM
The Following User Says Thank You to MB For This Useful Post:
PeeBee (18th December 2022)
18th December 2022, 08:33 PM
The Following 2 Users Say Thank You to MB For This Useful Post:
Cremulator (22nd December 2022), PeeBee (18th December 2022)
18th December 2022, 09:47 PM
The Following 2 Users Say Thank You to mudnut For This Useful Post:
PeeBee (19th December 2022), Stropp (20th December 2022)
20th December 2022, 11:33 PM
MB
Tapatalk won’t allow edits
I found tapatalk very limiting, don't use it anymore
21st December 2022, 02:16 AM
Patrol Guru
MB
It does, but it is a PIA. The forum is meant to be enjoyed over the computer IMHO.
I do use Tapatalk when I have a picture I took using my phone and want to post something involving that picture, so I don't need to transfer the picture to the computer and then post it on a topic. But other then that, I'd rather update myself on the several conversations using the good ol' PC.
21st December 2022, 06:56 AM
PeeBee
Phil your work is in a warmer climate in central QLD yes?. So not warming the cylinders pre start wouldn't matter. Much different to down here in cold Vic. My Territory, not new but a 2016 vintage, needs to be glowed on colder mornings, but warmer morning like today, I just got in and fired her up. They don't need a lot of heat to fire, high compression, high pressure fuel systems, and the injectors on late model vehicles spray the fuel like mist, unlike our old donks which is more like a fire hose spray, so the fuel atomises much better ready to ignite. So when you turn the key to start obviously the glow process starts immediately and I do believe the glow plugs stay on for a period of time after the engine has started to ensure proper fuel burn on a cold engine. The 3ltr ZD30 does this actually. A lot of people disconnect this feature as the OEM plugs are ceramic tipped and there has been cases of the tips falling off and bouncing around the pot like a pinball.
PeeBee (21st December 2022)
