12th December 2022, 08:05 PM
#11
What spec is the injector pump timing set at?
Who rebuilt the engine?
12th December 2022 08:05 PM
12th December 2022, 09:10 PM
#12
Injector pump timed at stock spec, I forget what it is now. I have tried advancing it and retarding it which made no difference to the noise
Rebuilt by some bloke on the goldy that does td42, 1hd
12th December 2022, 10:06 PM
#13
Ok. I have seen engines tick when the rings were tight in their lands after a rebuild. Could be something worth checking.
13th December 2022, 05:54 PM
#14
What would be the process in checking that? Should I contact the rebuilder or can I check that myself? I have also just checked my catch can 4000Km after rebuild and I was surprised that there was actually a bit of oil in it since its new I thought there'd be no blow-by.
15th December 2022, 10:49 AM
#15
lcorney
Rings will take some time to lap into the cylinders...
The builder should have given you a break-in proccess... oil change interval etc
And ah, if you could check ring gaps, you coulda rebuolt the engine... not a five minute job.
1989 LWB 5-Seat, TD42
1st February 2023, 06:59 AM
#16
Have you checked if the power goes off from glow plugs. Constant power on glow plugs caused a rattling noise from my td42...
1st February 2023, 08:19 AM
#17
Patrol Guru
Ilvesekesekene
That would cause pre-detonation I assume?
