13th October 2022, 11:52 AM
4.8 engine rattle on cold start
I have a 4.8 with 230k on it and it has a rattle when on clod start.can anyone recommend a good mechanic around the Caboolture area to get the valve adjustment done
tks
13th October 2022 11:52 AM
15th October 2022, 07:37 AM
Assuming it has adjustable rockers for the valves...it's a pretty straight forward job. Anyone with a feeler gauge, spanner and screwdriver can do it.
Could has hydraulic tappets and rattle is caused by lack of initial oil pressure? Or tappets worn out...
1989 LWB 5-Seat, TD42
22nd October 2022, 08:03 PM
TB48 have shims on the valve spring buckets & usually tighten up so I don't think the rattle would be there, maybe cam chain hydraulic adjuster or something, does the oil light go out quickly?
