Results 11 to 20 of 23
Thread: Need to build a half wall/ fence need some ideas…
    465 Post(s)
    Far from a Builder meself @mudski Mate but if near crumbling masonry potential edges, chemical anchors after careful tile water lubricated drilling and vibration hammering once through the pretty stuff could hopefully work?
    Expansion masonary type bolts are horrible near edges, chemical anchoring compounds of say allthread are available stronger than what they’re binding too…generally MPA wise
    I've heard of using chemical compounds but not zero about it, where to buy it, how to use it etc. I will look into this. Thanks.
    465 Post(s)
    I reckon you should have put brackets in before laying the pavers. Maybe you'll need to lift pavers & bolt some stirrups (or brackets) to the concrete & possibly need to cut the pavers around the bracket, or cut circular holes in the pavers & then fill the hole around the stirrup with concrete up to the level of the top of the pavers? The bottom of the post will then sit just above the paver with no risk of rotting out over time. I reckon having the stirrups on the edging would look look naff. You could use a mix of rectangular (rather than square) posts (ie 90 x ??) & if needed to get the aesthetic balance right either some thicker battens to attach the Colorbond too, or spacers attached to the posts to attach the battens to.
    Attachment 86050
    Crap drawing but hopefully you get what I mean. I'm sure there are plenty of alternatives but this is what I came up with. Just that I wouldn't choose to bolt to the pavers. I suppose you could drill right through the pavers into the concrete & use longer bolts? It'd be easier than what I've drawn.
    Attachment 86051
    Hindsight is a wonderful thing mate. We had so much on our minds when builds were going on, a few things were forgotten about unfortunately. Moreso the funds simply ran out for anything extra at the time. I thought about doing as your pic but haven't decided as yet.
    Thanks.
  4. #13
    465 Post(s)
    Way out of my knowledge depth here Mark.
    But how about "somehow" utilizing those H retaining posts. Somehow extending them upwards. Neatly attaching a bracket of some type from the outside of the wall, upwards and then securing the fence to those?
    I googled H retaining post extension and a few options popped up... Example below.
    Just brainstorming here.
    Attachment 86053
    This was on my mind but welding a piece to the outer flat side. This way is more work but would give better strength. I'd have to remove the top sleeper if I were to go this way. I will investigate this more when the rain stops. Thank you.
    Hodge (13th October 2022)
  6. #14
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Mark, Ramset make a chemical anchor systems (Chemset 101 and 502) and they do supply in spin capsule which would be best option for you. For use of the Ramset cartridge you need their dispenser (costly for small jobs).
    Check the video and look for the spin capsules, the 101 type chemical is contained in a class type enclosed tube and the kit also contains threaded studs and nuts. On impact of tube by steel threaded stud the tube shatters and mixes the chemical and cures with stud in situ.
    I have used Chemset to secure thread rod in masonary type walls to secure post brackets and the top plate to secure/hold down roof trusses.
    https://www.youtube.com/watch?v=q2iKgMKmFiM
  7. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    mudnut (13th October 2022), mudski (14th October 2022)
  8. #15
    WA Wheatbelt
    23 Post(s)
    Well, build it dear Liza, dear Liza. lol - with all due respect.
  9. #16
    465 Post(s)
    Excellent, thank you.
    So far for me, I think I will get the fence brackets that bolt or weld to the H posts. I will have to remove the top row of sleepers I know, but drilling so close to the edge has got me a little concerned.
  10. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Bidja (14th October 2022), Hodge (14th October 2022)
  11. #17
    Jul 2017
    37 Post(s)
    I would look at utilising the H posts as well (depending on how they are secured _ in ground with concrete / yes). Maybe use some angle section or similar "profiled up" or off the shelf brkts, so to support the cypress post in the two vertical direction. Structure needs to be stayed /angle braced some how and also to be prevented from pushing out.
    Could secure brkt to cypress post with say two thru bolts _ thru the same vertical axis 100mm apart (could use threaded rod or bolts with flanged purlin nuts (look good)
    https://www.blackwoods.com.au/fasten...0mm/p/01606956
    Purlin bolt are nom 30mm length, it is the nuts I am suggesting here with threaded rod (many options out there).
    To attach the rails, bugle batten screw to back of post or angle brkt into side of post and attach rails for infill with wall cladding (only suggestions mate).
  12. The Following User Says Thank You to Bidja For This Useful Post:
  13. #18
    465 Post(s)
    Can you come down and do it for me? Sounds like you know what your doing... I'll have to read what you said 30 times to let it sink in.
  14. The Following User Says Thank You to mudski For This Useful Post:
  15. #19
    Jul 2017
    37 Post(s)
    If you remove top sleeper as u suggested, will the paver handle that without damage?
    Guess you could re bead gap with coloured sikaflex.
  16. #20
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I assume this is for some fark tard office pen up his / her ass pen pusher council reg bullshit?
    Run Stainless Steel wire from a mount from you house bricks 2 where ever u need 2 end it
    OR
    Glass fencing
    What the width of the concrete sleeper?
