Results 1 to 3 of 3
Thread: GU Sagging Doors
    May 2017
    Tumut, NSW
    GU Sagging Doors
    The rear barn doors as well as the driver's door have all sagged.
    Is there a way of adjusting them?
    Jun 2018
    24 Post(s)
    On my driver's door I added some washers between the bottom hinge and body to lift the door.
    Apr 2021
    Brazil
    I suppose if you hold your door by the corner and force it up you will find some good play. Maybe a solution would be to replace hinge pins and bushes.
