8th August 2022, 12:29 PM
ZD30 will torque converter and plate fit to a manual engine
Hi, Engine in my auto has done 360K and have just sheared the little dowel from timing sprocket driving the cams, so same result as broken timing chain. I can get a manual engine and just do a swap "IF" its possible to swap the flywheel for the existing plate on the back of my existing engine, which is auto.
Thanks David
8th August 2022 12:29 PM
9th August 2022, 07:51 AM
I can't see why not. People are doing auto to manual conversions, vice versa, all the time.
Dagwill (9th August 2022)
9th August 2022, 08:18 AM
Maybe someone could check on their Nissan Fast to see if cranks are the same part #.
I can't see Nissan complicating production by having a different crank for manual or auto when there's no logical reason for it.
John
The Following User Says Thank You to jff45 For This Useful Post:
9th August 2022, 08:39 AM
jff45
Might be onto something John. But all these part numbers could well supersede to the one part number which this doesn't say.
Dagwill (9th August 2022), jff45 (10th August 2022)
10th August 2022, 08:19 AM
Cheers, Mark. Looks like the ZDs between 11.2002 & 08.2005 didn't have a crankshaft
John
