8th August 2022, 12:29 PM
ZD30 will torque converter and plate fit to a manual engine
Hi, Engine in my auto has done 360K and have just sheared the little dowel from timing sprocket driving the cams, so same result as broken timing chain. I can get a manual engine and just do a swap "IF" its possible to swap the flywheel for the existing plate on the back of my existing engine, which is auto.
Thanks David
8th August 2022 12:29 PM
9th August 2022, 07:51 AM
I can't see why not. People are doing auto to manual conversions, vice versa, all the time.
Dagwill (9th August 2022)
9th August 2022, 08:18 AM
Maybe someone could check on their Nissan Fast to see if cranks are the same part #.
I can't see Nissan complicating production by having a different crank for manual or auto when there's no logical reason for it.
John
The Following User Says Thank You to jff45 For This Useful Post:
9th August 2022, 08:39 AM
jff45
Might be onto something John. But all these part numbers could well supersede to the one part number which this doesn't say.
The Following 2 Users Say Thank You to mudski For This Useful Post:
Dagwill (9th August 2022), jff45 (10th August 2022)
10th August 2022, 08:19 AM
Cheers, Mark. Looks like the ZDs between 11.2002 & 08.2005 didn't have a crankshaft
John
