18th April 2021, 05:25 PM
#131
One modification at a time Ash Mate, document findings, then go next steps with clarity of what is and isn’t working.
Have never found the need for the blanking plate although I think they’re only for the TD42Ti variants?
The Following User Says Thank You to MB For This Useful Post:
Cremulator (18th April 2021)
18th April 2021 05:25 PM
18th April 2021, 09:02 PM
#132
Patrol Guru
The Following User Says Thank You to Cremulator For This Useful Post:
1st August 2022, 12:57 PM
#133
Moderator
MB
Well the good news is that all three appear to have identical dimensions including the TD27 88C according to the verniers.
Only difference I can find under poor light is that both the 82C & 88C have the ‘Jiggle Pin’ and rubber gaskets whereas the 76.5C does not have either.
So I tried to get an after market 88c thermostat last week and found a part number but would have to order it in. I though bugger that will go to Nissan and get a genuine.....
Just went to Werribee Nissan and gave him this part number. No Stock Anywhere in the Australian Network... I will check PaP and then consider an aftermarket I suppose. @AB I will let you know of i find one!!!
Check out my Toy -->
Rogue Dung Beetle
1st August 2022, 01:08 PM
#134
Moderator
Ok PaP don't have anything with that part number and don't have anything with 88c for a TD. He had an 82c.
@MB where did you get that 88c from mate?
Rogue Dung Beetle
1st August 2022, 01:27 PM
#135
I’ll head down the line later this arvo and see if our Nissan has them hiding out back still Daz, it’s where I bought all 3 from for these tests above.
MudRunnerTD (1st August 2022)
1st August 2022, 02:10 PM
#136
1st August 2022, 08:05 PM
#137
MudRunnerTD
https://www.amayama.com/en/part/nissan/2120005d12
Wont get it as fast but its a bucket load cheaper.
1st August 2022, 08:17 PM
#138
Oh well, after a due diligence pot test prior to installation one could piff the Genuine failure at Barry down the line….in person
1st August 2022, 11:00 PM
#139
Moderator
mudski
Cheers mate. All good. Deal is done and it's not sheep stations. Happy days.
Rogue Dung Beetle
1st August 2022, 11:09 PM
#140
TD42 - All Variants Aussie Water Thermostats
