Results 1 to 10 of 17
Thread: TD42 NA Blacktop Block Engine Mount Casting’s
    475 Post(s)
    G’day NP.com.au,
    Only out of honest interest whilst stripping down the old TD42 Blacktop. Does anybody know what the additional 2 x engine mount castings were for on these engines?
    Thinking maybe another vehicle setup like Nissan-Civilian bus or Overseas power plant applications possibly?
    465 Post(s)
    Probably for that or the TB engine mounting points as the block casting is the same I believe.
  4. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (12th July 2022), Rossco (12th July 2022)
    475 Post(s)
    Cheers Mudski Mate
    Reading that just got me excited starring hard at a TB Maverick outside the shed.
    Would it in theory be possible to TB block rebuild with a TD head and other internals required?
    Cheers Mudski Mate
    No.
    TD blocks are a dry liner block. The old ones get pushed out and the new ones get pressed in and then usually honed to finish. Rebuilding TD42's is a fine art. You need to find a good builder who has good experience in rebuilding them. Little things like not using liquid nitrogen to install the new liners. Making sure the parent bores are in good condition and if machined are machined correctly. Liner protrusion is also a big one. Little things on the procedure help here. For example if the block needs decking then it needs to be done prior to liner installation. Then if the liner protusion needs to be reduced then this will be done once they are pressed home.
  7. The Following 4 Users Say Thank You to nissannewby For This Useful Post:
    MB (12th July 2022), PeeBee (12th July 2022), Plasnart (12th July 2022), Rossco (12th July 2022)
  8. #5
    The blocks were used in a multitude of applications. Anywhere from our humble patrol to a bus as you mention also forklifts and marine applications.
  9. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
  10. #6
    109 Post(s)
    Cheers Mudski Mate
    Now Marko, just get the bloody GQ rebuilt and going again....then think of Frankensteining anything else later!! You are the crazy scientist of this forum we know, but at least keep one powerhorse in plowing mode please.
  11. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
  12. #7
    475 Post(s)
    Legend’s Thankyou
    In regards the old TD42 rebuild underway, I have openly thrown my hands up beyond my grubby shed skills a few posts/threads ago
    Just currently stripping it down to become a ‘crate motor’ easy fit
    Have emailed, spoken to quite a few internet sourced TD builders within 1,000km self delivered but everybody is fully booked until almost 2023!
  13. The Following 2 Users Say Thank You to MB For This Useful Post:
    PeeBee (12th July 2022), Rossco (12th July 2022)
  14. #8
    193 Post(s)
    Yeah fark seems everything has just gone crazy atm . . . Dropped into Boss Aluminium today to enquire about a couple boxes for some work utes which they've done before but aren't even doing anything custom as have massive backlog of standard stuff with 30 week minimum. . Seems everywhere you go things are out of control damitt. . .
  15. The Following User Says Thank You to Rossco For This Useful Post:
    MB (12th July 2022)
  16. #9
    195 Post(s)
    At least the story is consistent as they said the same for tray and canopy and that was even after they moved into bigger premises
  17. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (12th July 2022), Rossco (13th July 2022)
  18. #10
    @MB do you have a budget?
  19. The Following User Says Thank You to nissannewby For This Useful Post:
    MB (13th July 2022)
