25th March 2022, 08:33 AM
#5321
Darche Eclipse 270 awning and one awning wall to suit. All from Snowy's
The Following 6 Users Say Thank You to mudski For This Useful Post:
jay see (25th March 2022), jff45 (26th March 2022), MB (26th March 2022), MudRunnerTD (10th May 2022), Rossco (25th March 2022), rusty_nail (25th March 2022)
25th March 2022 08:33 AM
7th April 2022, 11:00 PM
#5322
Bigger 70cc hydraulic pump and 20,000lb hydraulic winch for the back to replace the Warn 15,000 electric
7th April 2022, 11:13 PM
#5323
PeeBee
Have you done the calcs for this? Do you know the specs at all of the PTO capacity? You will need 16hp to run that pump @ 1000rpm @1500psi. And about 110nm of torque when at the 1000rpm and 1500psi. I don't know the specs of the PTO output off the side of the patrol box just trying to make sure it's done right. Also you can't use a hydraulic winch if the engine isn't running, where an electric might flatten some batteries but could get you out of a lot of trouble before doing so.
rusty_nail (8th April 2022)
8th April 2022, 09:29 AM
#5324
Finally found some affordable cornering lights for my Series 2 fenders at AliExpress and didn't think twice!
The Following User Says Thank You to BrazilianY60 For This Useful Post:
8th April 2022, 08:48 PM
#5325
nissannewby
15kW at 525rpm, and yes am aware of the Pto operation
14th April 2022, 07:04 AM
#5326
Reason: Fixed photo layout
The Following 9 Users Say Thank You to Cremulator For This Useful Post:
jay see (27th April 2022), jff45 (14th April 2022), MB (27th April 2022), Mickhead (30th April 2022), mudnut (14th April 2022), mudski (14th April 2022), Plasnart (14th April 2022), rusty_nail (15th April 2022), Touses (14th April 2022)
14th April 2022, 09:26 AM
#5327
Is this raptor paint actually harder than standard 2 pack? would seem its going to be harder to wash with all those rough pockets? I do like the matt look though.
14th April 2022, 09:46 AM
#5328
It has a hardening compound that you mix with it before application.
The paint is actually like a soft jelly before you add the hardener to the bottle.
Hopefully a high pressure hose will be all that's needed to wash it if required.
Edit: best part was that I didn't need to get the surface preparation perfect and the raptor covered any rough areas.
You can see in this photo what it looked like after paint, but before raptor.
The Following 3 Users Say Thank You to Cremulator For This Useful Post:
MB (27th April 2022), PeeBee (14th April 2022), Plasnart (14th April 2022)
14th April 2022, 11:46 AM
#5329
Breadmaker Shaker
That has come up smicko mate! Mine’s looking a bit tired and you’ve given me food for thought.
The Following User Says Thank You to Plasnart For This Useful Post:
Cremulator (14th April 2022)
14th April 2022, 01:09 PM
#5330
16mm syn rope and protective sheath for the new hydraulic winch, box of jing ping
The Following 3 Users Say Thank You to PeeBee For This Useful Post:
MB (27th April 2022), MudRunnerTD (10th May 2022), Rossco (14th April 2022)
