Results 1 to 10 of 14
Thread: Hi All - CRD 3.0 turbo diesel 08 ST GU4
    Oct 2021
    Perth WA
    Hi All
    Realised I havent posted my Intro yet
    Lurking around here for years but only signed up last yr.
    So helpful and knowledgeable threads for a do it yaself tragics like my self is AWESOME!!
    Running a CRD 08 ST GU4 3.0l turbo diesel, lovingly treated with Liquimoly MO2, permalube conditioner. New kings springs and ultra long travel shocks.
    Fitted new aftermarket tie end rods and steering dampner.
    repaired drivers door lock (damn plastic rivets) THANKS TO FORUM THREADS...
    Replaced door speakers and window switches (thanks again threads)
    And hooked up oil catch can - plus MAFS after market wiring harness to air sensor to permanently keep ERG valve closed. (couldnt be bothered blanking it)
    Now needing to replace old stereo, broken electric antenna etc.
    Thanks everyone
  2. The Following 2 Users Say Thank You to Calts For This Useful Post:
    growler2058 (1st April 2022), MB (1st April 2022)
    Feb 2011
    Shed
    45 Post(s)
    G'day mate, welcome aboard
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
    584 Post(s)
    sunshinecoast
    3 Post(s)
    welcome calts . @Calts , could you please tell me more about this mafs wiring harness mod .
    Oct 2021
    Perth WA
    GDay Nipagu7
    https://www.aironboard.com.au/store/...g-modules.html
    Just a wiring loom that plugs between mafs sensor loom and connector to tell ECU to keep EGR valve closed/ also blanks comms to EGR codes (as seen from my scan gauge)
    useful little bit of kit, bought mine off ebay for 50 bucks.
    Hope that helps
    Now I'm trying to find wh I have fuel bleed back after 3 hrs of corrugated track driving (replaced two filters, hoses and prime lifter pump) could it be the dreaded relief valve on the fuel rail?
  9. #7
    sunshinecoast
    3 Post(s)
    ok , so the harness is basically the pink wire maf mod . with the air leak , you could replace the last flexible fuel hose before the Injector pump with a clear one temporarily ( make sure there is a upward loop in the hose ) . if after sitting over night air leaks in somewhere before the IP , it should collect at the top of the loop . have a look at it before starting the car , if there is no air bubble there get someone else to start the car while you watch the hose to see if any air comes thru . if you see air there the problem is somewhere between there and the fuel tank . a cheap and easy test before playing around with anything after that point .
  10. The Following 2 Users Say Thank You to nipagu7 For This Useful Post:
    BrazilianY60 (18th October 2022), Calts (21st October 2022)
  11. #8
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I have the same model, I was my happiest with an exhaust, intake clean and retune. Not a cheap process but worth the money.
    What was the issue with the drivers door lock?
    2008 CRD Auto Wagon
  12. #9
    Apr 2021
    Brazil
    Quote Originally Posted by Calts View Post
    Interesting. I have to investigate a similar issue in mine. Can you please point out the thread where you found the solution?
  13. #10
    Oct 2021
    Perth WA
    GDay Pollen
    Old dreaded door lock mechanism loses central pivot that holds it together when locking and unlocking - more noticable using central locking on remote.
    Could get bad to point it jams up and have to chisel inside door cover off to open door.
    Plastic rivet which snaps so remove and replace with steel bolt and nut.
