14th October 2021, 08:46 AM
#15591
Sprock
You were 105 @
PeeBee ?! Jesus last time I saw you there was nothin of ya - you Would’ve had to run around in the shower to get wet
For me thats getting uncomfortable, and working a desk job from home, snacking and slobbing around, just stacked it on. Affected sleep pattern as well. Anyway, i am trim and delicious again, so you will recognise me when we next meet ol' Sprockie Doodle!
The Following 3 Users Say Thank You to PeeBee For This Useful Post:
MB (15th October 2021), mudski (14th October 2021), Winnie (14th October 2021)
14th October 2021 08:46 AM
16th October 2021, 11:21 AM
#15592
Week of callout over . #SES volunteers are legends!
Few home made burgs , a stubby or 5 and then sleep...
The Following 6 Users Say Thank You to Hodge For This Useful Post:
Avo (16th October 2021), jay see (16th October 2021), MB (17th October 2021), mudnut (16th October 2021), Plasnart (16th October 2021), Rossco (16th October 2021)
16th October 2021, 06:05 PM
#15593
Got a call from Truckee that the patrol will be in Perth tomorrow morning sometime, can’t wait 👍
The Following 7 Users Say Thank You to Stropp For This Useful Post:
Avo (17th October 2021), MB (17th October 2021), mudnut (16th October 2021), mudski (26th October 2021), pearcey (16th October 2021), rusty_nail (16th October 2021), Woof (17th October 2021)
17th October 2021, 08:46 PM
#15594
Stropp
Good to hear matey,
The Following User Says Thank You to Avo For This Useful Post:
Stropp (17th October 2021)
25th October 2021, 10:36 PM
#15595
The Following 4 Users Say Thank You to rusty_nail For This Useful Post:
Cremulator (26th October 2021), jay see (26th October 2021), mudnut (25th October 2021), Rossco (26th October 2021)
26th October 2021, 08:35 AM
#15596
Nic, nice setup. I also run a large inverter(3500W) and battery bank (390a/h). I have a large alternator as well (300a/180a at idle). I find I use the battery bank feed to the inverter to charge small items like battery chargers for the makita chainsaw, without the alternator feed, but need the alternator running for other power tools or the coffee machine, I would say in the main the alternator runs most of the time as the current draw without the alternator top up depletes the battery bank too quickly. I certainly cant run the coffee machine for long without the alternator assist for example. If you can still run the inverter off the main bank for the small items you might get some flexibility. What size alternator is in the vehicle? For extended running of 240V power tools, if you need to go that way, that could be your limiting factor - being inability to top up the depleted charge.
rusty_nail (26th October 2021)
26th October 2021, 10:29 PM
#15597
Daily Lurker
PeeBee
I believe it is 120ah. What do I need to consider? It's not big enough? Lol
27th October 2021, 06:53 AM
#15598
rusty_nail
Managed to find the time to upgrade my battery bank to how it should have been done the first time. Scored the wires all crimped and heat shrunk for $5 per pair. Upgraded all wires to fuse and heavenly devices to suitable wires and also fitted a mini VSR to exclusively run my inverter. Now the inverter can only be on while car is running but can also be manually switched off. The inverter will run from the alternator rather than drawing power from the second battery via alternator charge. Works brilliantly and cost me less than $100
Wow, does that double as a battery bank for the house too? Thats a lotta battery!
27th October 2021, 09:31 AM
#15599
rusty_nail
Simple numbers, ignoring efficiency losses.
2400W = 240V x 10a, so converting to 12V power supply, 2400w = 12V x 200a (200amp is the draw on your battery bank, so 120a alternator would not cut that load), hence the load comes out of the reserve in the battery bank, not the alternator. Battery voltage drops, alternator tops it up, but as you can see in this example, the gap of 80a (200 V 120a) leads to an eventual flattening of the battery.
27th October 2021, 10:47 AM
#15600
Swimming pool auto close doors passed the compliance inspection, all legal, all legit, excellent rework by Nic @rustynail over a couple of visits. Stuff like this needs to be handled by the tradie for sure - i would have stuffed around and made a mince of it for sure.
The Following 5 Users Say Thank You to PeeBee For This Useful Post:
Cremulator (27th October 2021), MB (27th October 2021), mudnut (27th October 2021), Rossco (27th October 2021), rusty_nail (27th October 2021)
