Page 1556 of 1658 FirstFirst ... 556105614561506154615541555155615571558156616061656 ... LastLast
Results 15,551 to 15,560 of 16579
  1. #15551
    465 Post(s)
    How much can a Bundy bare?
    Cheers mate!
    Got a phone call from the local hardware store....nah not the green one....the one with dogs doing their shit....I mean advertising......just won the fsthers day competition for WA... it's taken a bit longer than usual as the first drawn winner is in jail so they did a redraw....and thank ya mother for the rabbits the next name drawn was mine...
  4. The Following 12 Users Say Thank You to Avo For This Useful Post:
    BrazilianY60 (23rd September 2021), Cremulator (20th September 2021), jay see (22nd September 2021), MB (20th September 2021), mudnut (21st September 2021), pearcey (23rd September 2021), Plasnart (20th September 2021), Rossco (20th September 2021), rusty_nail (20th September 2021), Touses (21st September 2021), TPC (22nd September 2021), Winnie (20th September 2021)
  5. #15553
    465 Post(s)
    I drove the Patrol to work today. 25k there and back of suburban driving. Fark me! It’s actually a joy to drive it! It’s never gone so good. The different setup with the boost controller has obviously done the engine good. Way less soot and boost is coming on a lot earlier and holding it high in the revs too.
    It’s a whole new beast to drive now.
  6. The Following 6 Users Say Thank You to mudski For This Useful Post:
    Avo (22nd September 2021), BrazilianY60 (23rd September 2021), Cremulator (23rd September 2021), jay see (22nd September 2021), mudnut (22nd September 2021), Rossco (23rd September 2021)
  7. #15554
    That's because you are using a proper boost tee instead of a needle valve. A needle valve will always allow flow through unless it is completely closed. So effectively you were always slowly bleeding to your wastegate and having it open before it should have been. The turbosmart one is like a relief valve. You are adjust the spring tension to an opening point. Once this point is reached the valve opens and allows the wastegate to open and control boost. This has its limitations and is why electronic controllers are so good.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
    mudski (23rd September 2021)
  9. #15555
    465 Post(s)
    Thanks Mat, makes sense.
    Another thing mate. Speaking with a customer of mine he suggesting to have the boost supply to the Tee on its own and NOT have it sharing supply with the injector pump. This way the compensator will get "actual" boost signal, not a shared signal which may be incorrect due the the controller bleeding off.
    Sound right to you.
  10. #15556
    175 Post(s)
    Glorious day up here .
  11. The Following 12 Users Say Thank You to Hodge For This Useful Post:
    Avo (23rd September 2021), Cremulator (23rd September 2021), jay see (23rd September 2021), MB (23rd September 2021), mudnut (23rd September 2021), mudski (23rd September 2021), nissannewby (23rd September 2021), pearcey (23rd September 2021), Plasnart (23rd September 2021), Rossco (23rd September 2021), rusty_nail (23rd September 2021), Touses (23rd September 2021)
  12. #15557
    Sound right to you.
    It will most likely be right. I, myself always like to have each thing have its own supply and also be supplied from closest to what's being fed into the engine. So usually in the intake manifold. As you have will be fine.
  13. The Following User Says Thank You to nissannewby For This Useful Post:
    mudski (24th September 2021)
  14. #15558
    109 Post(s)
    Nice one Eric! Are you on an adjacent parallel-line tower or is that from a drone? Are you in the pic?
    @mudski I hear there's an opening in the cherry picker if you're keen!
  15. The Following User Says Thank You to Plasnart For This Useful Post:
  16. #15559
    My wood stack is growing. I'm about 10% though the wood I collected from the storms. Should be right next winter
  17. The Following 7 Users Say Thank You to rusty_nail For This Useful Post:
    Avo (23rd September 2021), Cremulator (25th September 2021), jay see (24th September 2021), MB (23rd September 2021), MudRunnerTD (23rd September 2021), mudski (24th September 2021), Rossco (24th September 2021)
  18. #15560
    465 Post(s)
    Get stuffed! I hired a cherry picker to lop some trees at home. It only went up 12 metres and I was a nervous wreck when I had it fully extended.
  19. The Following 3 Users Say Thank You to mudski For This Useful Post:
    jay see (24th September 2021), MB (24th September 2021), Plasnart (24th September 2021)
