4th September 2021, 09:30 AM
#11
Hodge
Been locked down too long. Taking it for a drive and absolutely sink it. She'll boost in no time I reckon. lol
Haha tried that.
4th September 2021 09:30 AM
4th September 2021, 02:12 PM
#12
Moderator
Maxhead
….anyone say Y62
Me! Me! Me! It was Me!......
![Cool](images/smilies/cool.png)
Check out my Toy -->
Rogue Dung Beetle
mudski (4th September 2021)
4th September 2021, 02:15 PM
#13
Moderator
mudski
Update.
My Patrol is just sitting here. Lol.
Boost controller is fine, so are all the hoses and the IC is fine. Changed out the fuel filter and it didn't help. Theres no gauze screen on the inlet line going into the pump. So its either the motor or injector pump. I assume. In lockdown so no rush.
I would say yoy have a boost leak for sure. That explains the lack of boost and the black smoke as it is tuned for more boost so over feeling now. I woyld be tracing every boost hose looking for a split or blown hose . You may fine it just with the bonnet up and someone revving up the car.
Rogue Dung Beetle
4th September 2021, 08:32 PM
#14
MudRunnerTD
Already done this mate. Replaced every boost hose in there now. The only thing I haven't checked is the intercooler. But being a barely used Cross country Ic I doubt its the cause. I will look more into a few things when the weather warms up.
4th September 2021, 09:46 PM
#15
The Following User Says Thank You to MB For This Useful Post:
mudski (5th September 2021)
5th September 2021, 08:16 AM
#16
Have you taken a reading directly from the compressor with the wastegate firmly closed?
John
5th September 2021, 11:03 AM
#17
jff45
No. How do I do that?
5th September 2021, 02:18 PM
#18
Connect the gauge hose directly to the compressor housing outlet and remove the hose on the wastegate actuator.
Don’t go silly with it in case it boosts high before it overcomes the actuator spring
The compressor outlet will currently be connected to your boost controller which then feeds back to the actuator.
I assume your gauge hose is connected to your IC or manifold?
John
The Following User Says Thank You to jff45 For This Useful Post:
mudski (6th September 2021)
6th September 2021, 08:36 AM
#19
jff45
Yes my gauge reads from a port in the inlet manifold. Then another port T'd (one to the injector pump, one toward the boost controller), then to another T, (one to the boost controller and the other to the wastegate actuator) Apparently its plumbed like this for high boost applications.
So what should i see doing as you suggest John? What shouldn't I be seeing?
6th September 2021, 12:51 PM
#20
Moderator
mudski
You will be taking out the intercooler. straight off the actuator will show you the boost output at the turbo
Rogue Dung Beetle
