2nd September 2021, 01:34 PM
#13711
rusty_nail
I was discussing with a group on Facebook today about my roof rack. Sometime mentioned I should check if it had been riveted on or if it had been nutserted. I had a look this Arvo, sure enough it was riveted on, needless to say I find that pretty disappointing, I've had holes drilled in my roof and that wasn't disclosed when I bought the rack. There is no way of removing it if I need to either now.
I would be VERY suspicious of any rack that is riveted (or nutserted) onto the roof - unless all those fixings went into the supporting structure of the roof and not just into the jam tin thin roof material. There is just too little support for sideways forces and the pressures placed on them by off-road use. Rack loading needs to be very carefully considered, I think.
The Following User Says Thank You to Brissieboy For This Useful Post:
rusty_nail (2nd September 2021)
2nd September 2021 01:34 PM
2nd September 2021, 02:42 PM
#13712
Daily Lurker
Brissieboy
I'll be going there this Arvo and confirming they have reinforced the riveted section
2nd September 2021, 07:11 PM
#13713
Daily Lurker
So I went in to the tradesman roof racks shop in Bayswater this Arvo.
Regarding the rivets I asked him, and he assured me the mounts are drilled into the roof, in locations where the side panels overlap the roof panel and also the roof reinforcing crossmembers, so there is sufficient steel there to take the weight and wind load. I feel confident in his answer so I guess for me all good.
The only way really to be sure would be to peel back the roof lining and take a look but I'm not willing to do that.
The Following User Says Thank You to rusty_nail For This Useful Post:
mudski (2nd September 2021)
2nd September 2021, 08:30 PM
#13714
rusty_nail
Remove the rivets and nutsert the fecker. Rivets will eventually fatigue and break.
2nd September 2021, 08:55 PM
#13715
FWIW: Unsure, but please do consider there may not be enough depth in the cavity to insert a riv/nutsert and possibly why they’ve opted for a stubby/shorter expansion rivot instead Old Mate?
2nd September 2021, 09:16 PM
#13716
MB
Ahh yes old chap!* as I'm puffing on a pipe* But I would nutsert with a wide "mudguard" washer on the inside to assist. Its all about the footprint for grip....
2nd September 2021, 09:34 PM
#13717
Unsure of the roof cavity config, only meant Old Mate’s that from my experience elsewhere that trying to install say an M8/10 rivnut into a say 20x20mm SHS doesn’t work as rivnuts that I have on hand are too long and bottom out on the backing material before their grip designed half is in deep enough ready to compress if that makes sense?
2nd September 2021, 09:58 PM
#13718
MB
When I'm half cut. Nup....
The Following 3 Users Say Thank You to mudski For This Useful Post:
Avo (4th September 2021), Cremulator (2nd September 2021), MB (2nd September 2021)
2nd September 2021, 10:28 PM
#13719
Breadmaker Shaker
mudski
He's saying the stiff prong may be too long for the cavity pre-wrinkle.
The Following 2 Users Say Thank You to Plasnart For This Useful Post:
MB (2nd September 2021), mudski (3rd September 2021)
2nd September 2021, 10:35 PM
#13720
