25th August 2021, 01:19 PM
Ebay kit, gas strut for left barn door
I'm going to give this a go, hopefully better than the bit of pipe I'm currently using to sandwich between the doors
Link Here
2008 CRD Auto Wagon
25th August 2021 01:19 PM
25th August 2021, 02:44 PM
Patrol Guru
It looks like this eBay listing is packing up this tutorial from the Patrol4x4 forum.
https://www.patrol4x4.com/threads/gu...ut-mod.409567/
All parts from Bunnings for about $30.
25th August 2021, 03:48 PM
Heh, good find
2008 CRD Auto Wagon
The Following User Says Thank You to pollenface For This Useful Post:
Cremulator (25th August 2021)
25th August 2021, 04:17 PM
Bloody great idea, I did mine years ago.
25th August 2021, 08:45 PM
25th August 2021, 09:00 PM
Patrol Guru
The Following User Says Thank You to Cremulator For This Useful Post:
25th August 2021, 09:33 PM
The Following User Says Thank You to MB For This Useful Post:
25th August 2021, 09:42 PM
#8
25th August 2021, 10:51 PM
#9
Patrol Guru
I haven't installed a gas strut on mine, but I'd say if you did the gas strut first, then fitted the extension bracket the strut extension would probably still work fine.
The instructions also say "Lift up strut so ball stud is touching the middle of the panel on the underside of the door. Make a mark 10 to 20mm towards the body of the car in the middle of the panel. (This is so the strut isn’t fully extended when door is open)"
So you'd have a bit of extension play if you followed that guide, and the extension hinge wouldn't add much more than 10mm I would think.
25th August 2021, 11:13 PM
#10
