Results 1 to 8 of 8
Thread: front wheel wobble
    Expert jman69's Avatar
    S.A.
    front wheel wobble
    Hi there, just wondering, if i take out the shim from the top swivle bearings only and not the bottom ones would that be ok? or do i need to take out top and bottom shims? I don't want to go from to loose to too tight, baby steps?
    331 Post(s)
    one at a time should be fine mate
    S.A.
    Ok, thanks Mudrunner. Thatt was what i was hoping to hear.
    Advanced sussgq's Avatar
    Dec 2020
    it’s not a good solution.
    if you don’t have the same shims top and bottom, it will cause the axle to not be centred in the end of the diff housing which will contribute to premature axle oil seal failure. there’s factory preload settings for a reason
    S.A.
    I see what you're saying, that makes sense.
  6. #6
    S.A.
    ok, so today i removed the shims from all swivle bearings. There was one shim at each bearing, now there are none. Went for a test drive and found that the wobble was completely gone. Normally it comes at about 90 kph but today,nothing! Once again i'm a happy little patrol driver.
  7. The Following 2 Users Say Thank You to jman69 For This Useful Post:
    MB (12th June 2021), Mickhead (12th June 2021)
  8. #7
    Dec 2020
    Quote Originally Posted by jman69 View Post
    keep in mind that once the wobble begins it typically indicated rooted kingpin bearings. taking shims out will fix it but not for long, it stops it because it increases bearing preload immensely.
  9. #8
    S.A.
    Yes , i'm all too aware of that. But she'll be ok for a while though. I've put the shims in a safe place for when i eventually change the swivle bearings.
