Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 69
Thread: GUII heater core replacement
  1. #31
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    I didn’t study it too closely but I assume it shuts off progressively depending on the flap position. It would logically be fully closed when the flap is closed such that no air passes through the heater core. Halfway flap would probably be half flow hot coolant.
    I’m happy I don’t have the tap so I don’t need to worry about reusing an old unit.
    John
  2. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    Hodge (18th June 2021), MB (19th June 2021)
    Morayfield, QLD
    13 Post(s)
    Made a start on it this afternoon. Nothing difficult up to this point.
    I’m surprised I had a hollow TX50 spanner to get the airbag bolts out..
    John
  5. The Following 5 Users Say Thank You to jff45 For This Useful Post:
    0-TJ-0 (18th June 2021), BrazilianY60 (24th November 2022), Hodge (18th June 2021), MB (19th June 2021), mudski (18th June 2021)
  6. #33
    Have fun mate. When I did mine I made entire new, "aftermarket" wiring looms for all the "bolt on " accessories.
  7. The Following 2 Users Say Thank You to mudski For This Useful Post:
    jff45 (19th June 2021), MB (19th June 2021)
  8. #34
    Morayfield, QLD
    13 Post(s)
    Yes, I need to do some serious tidying up in the wiring. The hardest part will be tracing what some of it does but that’s ok, I’m in no hurry.
    I find this kind of thing is a pretty satisfying way to stay active during retirement
    John
  9. The Following 3 Users Say Thank You to jff45 For This Useful Post:
    BrazilianY60 (24th November 2022), MB (19th June 2021), mudski (19th June 2021)
  10. #35
    Morayfield, QLD
    13 Post(s)
    The centre radio surround in 'faux bois' has cracked in several places so I'm thinking of 'reconstructing' it with superglue/baking soda and vinyl wrapping it in 3M carbon fibre. This means I'll have to do the shifter surround as well so it doesn't look too silly. Probably won't bother with the door trim 'faux bois' bits.
    Anyone done this already? I've been watching a few YT vids and it looks like a patient DIYer could handle it.
    John
  11. The Following User Says Thank You to jff45 For This Useful Post:
    MB (19th June 2021)
  12. #36
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I just picked up some from the post office(eBay) yesterday to have a go at doing my bonnet scoop. All the clear coat came off it. Thought it seemed like an easy part to have a go at wrapping (except I don't know how I'm going to do the inlet hole). I don't really want the scoop to be carbon fibre but I thought it might look less sh.t than faded paint.
    I think it only cost $20 for a reasonable sized piece. Haven't pulled it out of the envelope yet.
  13. The Following 2 Users Say Thank You to 0-TJ-0 For This Useful Post:
  14. #37
    Morayfield, QLD
    13 Post(s)
    I've ordered 3M brand stuff and the 1524mm x 500mm sheet is around $60. Also ordered a kit with the squeegee, etc.
    Carbon fibre was just the lesser of all evils because I don't want coloured stuff nor matt black or brushed silver, etc.
    Throw up some pics when you get into it..
    John
  15. The Following User Says Thank You to jff45 For This Useful Post:
    MB (19th June 2021)
  16. #38
    Morayfield, QLD
    13 Post(s)
    John
  17. The Following 5 Users Say Thank You to jff45 For This Useful Post:
    0-TJ-0 (19th June 2021), BrazilianY60 (24th November 2022), MB (19th June 2021), mudski (19th June 2021), Rossco (19th June 2021)
  18. #39
    193 Post(s)
    Yeah wow big job, good luck
  19. The Following 2 Users Say Thank You to Rossco For This Useful Post:
  20. #40
    Jan 2017
    South Australia
    11 Post(s)
    After reading your reply this morning I thought I might be better off ordering some 3m stuff too. Turns out the sheet I ordered was only $13.. thought it might be good to have a practice sheet anyway.
    Bit of a learning curve trying to get it to go around corners.. took me the better part of an hour to get this far on an old toolbox lid.
  21. The Following 4 Users Say Thank You to 0-TJ-0 For This Useful Post:
    Cremulator (19th June 2021), jff45 (19th June 2021), MB (19th June 2021), Rossco (19th June 2021)
