16th June 2021, 07:23 PM
16th June 2021 07:23 PM
16th June 2021, 08:34 PM
Oh wow old girls got sums decent compression going on. . Assume you gave it all few goes and checked for tight seal on the suspect one as could just be slightly squed reading? ?
16th June 2021, 09:00 PM
Squirt a smidgen of oil onto the bore of number 5. If the reading rises quite a bit, it has a stuck ring or worn rings. If it only rises a little, then a valve is the problem.
The Following 2 Users Say Thank You to mudnut For This Useful Post:
MB (16th June 2021), Rossco (16th June 2021)
16th June 2021, 09:13 PM
16th June 2021, 09:17 PM
Since its above the minimum, my idea isn't relevant. Have you got an inspection camera to see if it has the same amount of carbon build up as the others?
16th June 2021, 09:23 PM
16th June 2021, 09:26 PM
16th June 2021, 09:32 PM
No problem, Mark. Would a dribbling injector clean out some of the carbon? Nissannewby would be the one to ask. Bugger the camera can't see around corners. Mine came with a mirror.
16th June 2021, 09:48 PM
Accidentally topped up nearly half a tank of Petroleum into our Old Mans 2.4L diesel Hilux as a kid, that sure Bunnyhopped the carbon clean out of it in the day, knocked all the carbon out of me too driving it home from the servo until the realisation ![](http://s3.amazonaws.com/tapatalk-emoji/emoji23.png)
19th June 2021, 08:23 PM
