Page 1000 of 1053 FirstFirst ... 50090095099099899910001001100210101050 ... LastLast
Results 9,991 to 10,000 of 10522
  1. #9991
    195 Post(s)
    Glowing as in the accessories weren't lighting up properly or the actual joint was glowing?
    Joint glowing, high resistance/poor connection
    22 Post(s)
    Honestly, its a pretty big deal to achieve a glowing joint. You really should reterminate the cable at a minimum. Ideally replace the cable.
    96 GQ coil/Cab
    08 G6eT
  4. The Following 3 Users Say Thank You to Ben-e-boy For This Useful Post:
    MudRunnerTD (22nd March 2021), nissannewby (21st March 2021), PeeBee (21st March 2021)
  5. #9993
    465 Post(s)
    Whats the latest with your Patrol Ben?
  6. #9994
    22 Post(s)
    It's basically just like the soviet union.
    96 GQ coil/Cab
    08 G6eT
  7. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  8. #9995
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I installed my Big Bertha Oven on the cargo barrier. Should be able to do a nice roast in this sucker while driving to camp.
    2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
  9. The Following 7 Users Say Thank You to stevemc181 For This Useful Post:
    AB (22nd March 2021), jay see (22nd March 2021), MB (23rd March 2021), mudnut (22nd March 2021), Rossco (22nd March 2021), rusty_nail (22nd March 2021), Stropp (11th April 2021)
  10. #9996
    193 Post(s)
    Ooh nice, tried out my little bertha in Tas, Im sold threre bloody good
  11. The Following 3 Users Say Thank You to Rossco For This Useful Post:
    MB (23rd March 2021), rusty_nail (22nd March 2021), stevemc181 (23rd March 2021)
  12. #9997
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I noticed while testing it gets quite hot on the outside, a lot hotter than my small TB oven ever got, but it also gets a lot hotter inside than the small TB. I'll throw the temp gun on it when I go away at easter and see how hot it gets externally. I've thrown a bit of insulation on top of it to shield the Patrol roof a bit, helps stop the oven shaking while I drive as well. My first cook will be a a nice rack of lamb I think on the way out bush at easter.
    Current draw was about 19.5 amps with both elements going full bore, no drama's while driving, but need to watch power usage if camped up.
  13. The Following 2 Users Say Thank You to stevemc181 For This Useful Post:
    MB (23rd March 2021), PeeBee (23rd March 2021)
  14. #9998
    Put the GU on the Hoist to start fitting the sliders up and noticed the front wheel bearings were very loose... pulled a hub off the tighten and could not so have now stripped the front end damn it!
  15. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (5th April 2021), mudnut (5th April 2021), Rossco (5th April 2021)
  16. #9999
    Aug 2020
    Brisbane
    I started the long list of jobs when you first get a patrol. First remove 3rd row seats (anyone in Brisbane want them?). Adjusted doors that did not close properly. Looked at all the strange home wiring (job for another day). Removed Rear Wheel carrier (Rock Armor) to replace bearings but could not find a replace bearing as not standard Ford/Holden bearings (job for Monday). Cleaning, lots of cleaning. Add to already long list of things to do. oh, and brought a Milford cargo barrier for $70.
  17. The Following User Says Thank You to stricky For This Useful Post:
    MB (10th April 2021)
  18. #10000
    Expert Mickhead's Avatar
    Oct 2019
    Was driving home from Bunnings yesterday, slowing down for traffic lights, not quite coming to a complete stop.. When I started to move forward the poo let out a small “ FFT FFT “ sound, like driving over a sheet of plasterboard some tradie dropped...And lost all power. Drove it off the road with the starter motor. RACV bloke suggested fuel issues, however I thought it was cranking faster than usual on the starter motor, compression loss?
    Started autopsy today. Shes Farked. Time for an Amarok.
  19. The Following 2 Users Say Thank You to Mickhead For This Useful Post:
    MB (25th April 2021), mudnut (25th April 2021)
