Page 83 of 105 FirstFirst ... 3373818283848593 ... LastLast
Results 821 to 830 of 1047
  1. #821
    Patrol Guru matfew's Avatar
    Nov 2012
    Where are you located? I have used a hole saw on a drill press and was amazed how well it cut. If you have access to 1 it will blast through it.
    I've cut 8 32mm holes through 10mm stainless plate and using right technique and fluid, hardly even put any wear on the holesaw.
    I use them everyday at work on various material and got to say pay for decent ones. They will be so much better than cheap. Sutton are a good start. Milwaukee ones seem to be ok but I have a kit which is called reload. Has quick change setup and has been great. I've only just recently broke the 20mm and it's about 7 years old
    Sent from my BV9800Pro using Tapatalk
  2. The Following User Says Thank You to matfew For This Useful Post:
    Rossco (24th March 2021)
    Expert Mickhead's Avatar
    Oct 2019
    Quote Originally Posted by pollenface View Post
    I didn't think of hole saws, might see if I can blunten one of those
    13mm because those are the drills I have
    A Sutton kit is damn expensive, I'm sure it would last a lifetime though!
    Thanks for your input all
    Another option...
    Aldi step drill kit. 3 lovely golden HSS chinese pieces of joy costing a whopping $13 giving a range from 4 to 32mm in 2mm steps.. With 3 flats on the shaft to prevent slippage in the shyt milwaukee chucks.
    Drill in to the 10 mm plate from both sides on a drill press and you will have a lovely chamfered hole.
    Seriously, I have drilled hundreds of large holes thru up to 5mm 316 staino in an industrial environment with these. Using Rocol cutting oil and a slow speed they are still like new and shiny and golden 😀😀😀
  5. The Following User Says Thank You to Mickhead For This Useful Post:
    MB (25th March 2021)
  6. #823
    Being meaning to get a get of these, 50% off and 10 bucks in my loyalty account can't go wrong for 40 bucks..
  7. The Following 3 Users Say Thank You to jay see For This Useful Post:
    MB (26th March 2021), MudRunnerTD (26th March 2021), rusty_nail (26th March 2021)
  8. #824
    330 Post(s)
    There is no Down side there...
  9. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    jay see (27th March 2021), MB (27th March 2021)
  10. #825
    Does this count as a tool.
    Freebie at Bunnings today. Ryobi had a demo on their battery topper inverter.
  11. The Following User Says Thank You to jay see For This Useful Post:
  12. #826
    475 Post(s)
  14. #827
    196 Post(s)
    Guys, I picked this up recently after a solid recommendation from a guy on site who has used them for many years. They were configured for the NASA space program and have a special pressurised ink cartridge and writing tip that will write on just about everything. He uses his on bricks and tiles and wood, oily waxy coatings etc and swears by it. I have not tried this range of duties but it certainly performs on rough face plywood and straight to paper without missing a beat, no scratching around trying to get it to write. Very expensive for what it is but i have used it writing on wet steel corroded pipes with Sulphuric acid and it delivers like on paper - very impressive, certainly niche. Recharged or new cartridges are avail also.
    https://www.ebay.com.au/itm/Fisher-S...72.m2749.l2649
  15. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (27th March 2021), MudRunnerTD (28th March 2021)
  16. #828
    475 Post(s)
    A pressurised space ink cartridge really?
  17. The Following User Says Thank You to MB For This Useful Post:
  18. #829
    475 Post(s)
  19. The Following User Says Thank You to MB For This Useful Post:
  20. #830
    475 Post(s)
    Three (3) clicks Philstar you Mad Scientist Mate
    https://youtu.be/PxNKtCv8SW8
