7th March 2021, 11:15 PM
#101
7th March 2021 11:15 PM
8th March 2021, 07:31 AM
#102
@MB, notice you are running a roller fairlead - steel cable or rope? Install looks great. Have you welded the rope deflector device to the frame - if so, good idea, stronger than the bolts for sure.
8th March 2021, 09:41 AM
#103
All welded Mate, no bolts on the front at all.
It’s the roller fairlead that came with it, hopefully that’s ok for the 12mm rope I’m intending?
8th March 2021, 11:15 AM
#104
MudRunnerTD
Is this of any help brother
Nothing like the Sherpa drawing either daz. They have only 2 wires to the second motor and 2 of the other 2 bolts are joined together not running to the solenoid. It's a weird probity but hoping with some help from Sherpa I can get it going right
Sent from my BV9800Pro using Tapatalk
The Following 2 Users Say Thank You to matfew For This Useful Post:
MB (8th March 2021), MudRunnerTD (8th March 2021)
8th March 2021, 11:17 AM
#105
Didn't even think of it yesty. Rope will get jammed between the rollers on the right angle. That's why all normal winches use the alloy solid fairlead so nothing to get caught on. Might have to look at changing that. I can pull mine off if we need
The Following User Says Thank You to matfew For This Useful Post:
8th March 2021, 11:39 AM
#106
Yeah not recommended or ideal but our 75 ute has rollers and rope and so far never had an issue with it, had to pull at a pretty extreme angle before and all good. . Might have a spare ally one in shed if you want it, can even paint it yellow. .
8th March 2021, 11:45 AM
#107
8th March 2021, 12:01 PM
#108
8th March 2021, 12:28 PM
#109
Mark mate, I've still got my old roller off my TJM bar. It's yours if you need it.
The Following User Says Thank You to jay see For This Useful Post:
8th March 2021, 01:44 PM
#110
