Page 11 of 15 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 142
Thread: Rear Winches - Lowering Down versus Hauling Dead Vehicles Up
  1. #101
    475 Post(s)
    Legend Cheers Daz
    Solenoid #1 (main) is within the control box and we don’t want to crack the seal at this stage voiding. Solenoid #2 is a mini Albright 125amp jobbie for secondary motor hauling in only not outwards I believe?
    195 Post(s)
    @MB, notice you are running a roller fairlead - steel cable or rope? Install looks great. Have you welded the rope deflector device to the frame - if so, good idea, stronger than the bolts for sure.
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (8th March 2021)
  5. #103
    475 Post(s)
    All welded Mate, no bolts on the front at all.
    It’s the roller fairlead that came with it, hopefully that’s ok for the 12mm rope I’m intending?
  6. #104
    Patrol Guru matfew's Avatar
    Nov 2012
    Is this of any help brother
    Nothing like the Sherpa drawing either daz. They have only 2 wires to the second motor and 2 of the other 2 bolts are joined together not running to the solenoid. It's a weird probity but hoping with some help from Sherpa I can get it going right
    Sent from my BV9800Pro using Tapatalk
  7. The Following 2 Users Say Thank You to matfew For This Useful Post:
    MB (8th March 2021), MudRunnerTD (8th March 2021)
  8. #105
    Nov 2012
    Didn't even think of it yesty. Rope will get jammed between the rollers on the right angle. That's why all normal winches use the alloy solid fairlead so nothing to get caught on. Might have to look at changing that. I can pull mine off if we need
  9. The Following User Says Thank You to matfew For This Useful Post:
    MB (8th March 2021)
  10. #106
    193 Post(s)
    Yeah not recommended or ideal but our 75 ute has rollers and rope and so far never had an issue with it, had to pull at a pretty extreme angle before and all good. . Might have a spare ally one in shed if you want it, can even paint it yellow. .
  11. The Following User Says Thank You to Rossco For This Useful Post:
    MB (8th March 2021)
  12. #107
    475 Post(s)
    I think this specific design one will be ok looking at it
    Certainly is advertised/written with this winch for your choice of either cable or rope.
    Will compare the roller overlap against an old TJM roller I have hidden somewhere
    Rossco (8th March 2021)
  14. #108
    475 Post(s)
    Can’t find the old TJM variant roller but pretty sure it didn’t have as much overlap and height on the sides as this one, can’t really see it being a problem and happy for the extra roller assistance on the soft rope
  15. #109
    49 Post(s)
    Mark mate, I've still got my old roller off my TJM bar. It's yours if you need it.
  16. The Following User Says Thank You to jay see For This Useful Post:
    MB (8th March 2021)
  17. #110
    475 Post(s)
    Cheers John Mate, Appreciated
    I think this Sherpa one will be ok, hard to test at the moment though, motors are playing funny buggers
  18. The Following User Says Thank You to MB For This Useful Post:
    jay see (8th March 2021)
