Results 1 to 10 of 11
Thread: power windows,, clean and rebuild switch, handy use of silicon.
    Jan 2017
    Yes passenger windows went down, wont go up.
    flip up armrest , remove screw, remove switch, disconnect switch so you can take it to bench or kitchen table.
    Use small screwdriver on sides of switch between black and white to ease out from lock bumps.
    small part that slides to and fro can now be removed, again by screwdriver easing the sides out that hold it.
    BEWARE there are two small springs and ball bearings, dont loose them.
    Find spots where carbon has built up on contact points, clean up with fine sandpaper.
    I found it VERY difficult to keep springs and balls in correct place as i reassembled.
    SO
    Take small part of switch that houses springs, using a tiny screwdriver place tiny bit of silicon sealant on end of spring.place the spring home.
    Now put a tiny amount of silicon on the end of the spring you can see, carefully place balls on top of springs.let dry for a few hours.
    Now the switch can be easily reassembled.
    Good luck
  2. The Following 4 Users Say Thank You to Dagwill For This Useful Post:
    BrazilianY60 (20th February 2024), MB (5th March 2021), mudski (5th March 2021), rusty_nail (5th March 2021)
    Nice write up mate. I could have used this a few times
    465 Post(s)
    I used vaseline to keep the spring and the tiny ball in place while assembling the switch. One of my switches was beyond repair so being the tight ass I am I bought a Chinee knock off switch. Installed it, and the switch works in reverse. Lol.
    Apr 2021
    Brazil
    Do you have links for these knock-offs? Haven't opened them yet but my driver's side ones seem they don't even have springs in them, LOL.
    465 Post(s)
    Mate it was just from eBay. That long ago I cannot remember. I could probably alter the wiring in the plug so the window switch is correct but I'm so used to it now I'd get all confused if I made it right.
    Apr 2021
    Brazil
    My GQ ones are falling apart. If I can't find a OEM style replacement, I'll end up having to use something locally available but it will require some craftsmanship to create a new door handle to house it.
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    These may do the job. At that price they are worth a try.
    https://www.ebay.com.au/itm/14435658...3ABFBM3qqp3blj
  10. #8
    465 Post(s)
    Which ones do you have on this link?
    https://patrolapart.com.au/product-s...+window+switch
  11. #9
    Apr 2021
    Brazil
    I saw these types online but never listed as GQ. You are right, it may be worth buying just one and see if it fits on the GQ slot. Would need to find the connector for this one though.
  12. #10
    Apr 2021
    Brazil
    My GQ is a series 2 and has the switches that you pull up and down like "modern" cars:
    My donor/parts car is a series 1 and has the older rocker switches that look like door lock switches. It is not in a good shape either but kind of more refurbishable then the S2 ones. I am a bit against investing time on them because I only have them for the drivers door, and I would end up with two different types on the same car.
  13. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    mudski (23rd February 2024)
