Page 996 of 1054 FirstFirst ... 49689694698699499599699799810061046 ... LastLast
Results 9,951 to 9,960 of 10538
  1. #9951
    475 Post(s)
    Snuck a couple of insomniac hours in on the GQ this morning before school runs
    Plumbed the new Catch Can & mini ARB locker compressor finally into the fresh air Black Mamba airbox
  2. The Following 3 Users Say Thank You to MB For This Useful Post:
    Cremulator (1st March 2021), mudski (1st March 2021), Rossco (1st March 2021)
    195 Post(s)
    @MB, I dont think the insulation I have is going to work that close to the heat source - its going to melt - best look at something else I think
    MB (1st March 2021)
  6. #9953
    475 Post(s)
    Cheers Philstar, appreciate the initial kind offer anyways Mate
  7. #9954
    Patrol God Stropp's Avatar
    31 Post(s)
  8. The Following 5 Users Say Thank You to Stropp For This Useful Post:
    Hodge (2nd March 2021), MB (2nd March 2021), mudnut (2nd March 2021), Rossco (2nd March 2021), rusty_nail (2nd March 2021)
  9. #9955
    475 Post(s)
    Rear winch cradle beast is finally test bolted into position tonight, need to plumb up the new coil inner airbags ASAP as old Grandpa Spec GQ drop some 5mm on the rear new spring measurements taken prior
  10. The Following 4 Users Say Thank You to MB For This Useful Post:
    mudnut (2nd March 2021), PeeBee (2nd March 2021), Rossco (3rd March 2021), Stropp (2nd March 2021)
  11. #9956
    Expert Truckus's Avatar
    Feb 2021
    Central Coast NSW
    Found issue with cooling and temp gauge gremlin.
    Bad news...now onto Brunswick in WA organizing warranty claim for what is either cracked heads or blown head gaskets on an engine 11 months old with 28000 Kms on it.
    Found coolant tank was pressuring even on cold start as was running on OBD scan on the temp sender output to get a confidence check that the gauge is telling me good info (as was prepping to have digital A/M gauge installed). It was and coolant still cool and the signal was correct, but reservoir already bubbling and gurgling. suggesting exhaust gas pressuring cooling system.
    So Tee kay test...and just of the vapor (after draining coolant a bit so it would not go into test chamber and foul readings) coming out og the top of the res, 4 squeezes and she yellow shifted...so..gasket or head crack.
    Also fund condensation in EGR valve, but no signs of coolant in sump oil or oil filler cap, nor any soot build up in coolant.
    Anyhow, engine still has 25 months warranty or another 31000 Kms on it so now gt to find a way to get it fixed without having to pay to get the car freighted from NSW to WA and back again ( a few grand there at least).
    Now in all the time I have owned it, it has never gotten over 3/4 temp on gauge for more than 20 seconds and thats only after ten minutes from cold start before it settled back under half, and then stayed there all day for hot start or constant running, so to my knowledge engine has never kettled or boiled over.
    So pretty pissed off atm, and hoping Brunswick has a plan in place to honor warranty for a 27 K install, and another 2K road haul for delivery.
    Have spoken with head tech twice now, and he is getting back to me today.
    Let us see what happens.
    2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
  12. The Following 3 Users Say Thank You to Truckus For This Useful Post:
    jay see (5th March 2021), MB (3rd March 2021), Stropp (4th March 2021)
  13. #9957
    195 Post(s)
    Send an email to Greg sat BD, admin@brunswickdiesels.com.au. Follow up with phone call to Linda or Kerira-lee, explain the situation. Leave it 3 hrs then ring them back, speak with Greg only, the other two guys work for him but they can't make warranty decisions. Detail the exact symptoms and what you have done to reach where you are. Ask Greg where you can take it for an assessment, you need to let him make the decisions rather than make demands, it's simply the way that works with him. I would be wry surprised if he knocks you back because the motor is still under warrany.
  14. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    MB (3rd March 2021), MudRunnerTD (4th March 2021), mudski (5th March 2021), Truckus (3rd March 2021)
  15. #9958
    Feb 2021
    Central Coast NSW
    Cheers mate, so far I have been detailed of to Scott, so I will chat with you tomorrow.
    Adz
  16. The Following User Says Thank You to Truckus For This Useful Post:
    MB (3rd March 2021)
  17. #9959
    Explain to me again MB why you have not got an "MB's GQ play car" Build thread going mate. Get onto it mate, all your history will be lost in this thread mate. I regret never starting a build thread for the GU. Would have been great to log the journey. So glad I have it all documented for the GQ.
  18. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (5th March 2021), Rossco (4th March 2021), rusty_nail (5th March 2021)
  19. #9960
    475 Post(s)
    How dare you title Golden Gramps as a “play car” Mate......he is still a serious ‘workhorse’
  20. The Following User Says Thank You to MB For This Useful Post:
    Rossco (5th March 2021)
